Results 11 to 14 of 14
January 24th, 2003 03:52 PM #11
Have your brakes checked. Just remember mas mura magpagawa ng brakes kesa magpalibing. :wink:
- Nov 2002
- 82
January 25th, 2003 08:26 AM #12ok mga sir di ko na po uulitin pero kinabahan talaga ako dadalin ko na din po sa mekaniko to be sure pero sa tingin ko overheat nga ang pads dahil sa highway kami nagarangkadahan e bali wala lang ako magawa nung pauwi na ako para lang nainip siguro ako tapos may kotse na bigla ba namang sumingit sa akin at pinaharurot ang auto niya kaya siguro uminit ang ulo ko pero di ko na po uulitin well salamat po sa mga advice ninyo sa uulitin!!!!
January 25th, 2003 03:06 PM #13
Nangyari na sa akin iyan. I was not racing at that time pero mabilis ang takbo ko and the FX beside me lost control and swerved into my lane.
The culprit was the vacum assist for the brake system. Biglang tumigas yung pedal from right under my right foot. Akala ko tuloy brake failure.
When your vacum assist fails, it does not mean your brakes have failed. Nawala lang yung power assist niya. Parang power steering failure ba. You still have the same braking power but you need a helluva lot more muscle to fully utilize, it.
- Jan 2003
- 611
January 25th, 2003 03:30 PM #14sakin din nangyari na yan pero ang cause is--- tingin ko nangibabaw lang init ng ulo ko over sa presence of mind ko sa pagdadrive... :wink: pero pa-check mo na nga yang auto mo...
ingat ka pare sa susunod!
When was the last time you changed them? If it's been a while, I suggest following your mechanic's...
Rubber boot question (repair or replace)
