Results 1 to 14 of 14
    nagulat ako ng humataw ako kinarera ko kahapon yung corolla pag dating sa trpik pepreno na ako biglag nawala tumigas pero medyo kumagat din ng konti bakit kaya nagkaganun pero ngayong umaga balik na ulit ang preno
    baka may mechanical trouble lang.................sa tuhod mo pre! d nakayanan ng reflexes mo :wink: joke lang
    baka naman kasi matulin d mo lang napansin na kagat na preno or better yet baka naman d match ang 0-60 KPH sa 60-0 KPH set-up ng ride mo......
    Isa lang ibig sabihin nyan... Drive Safely...wag mo na ulitin yon warning na sayo yon.
    Racing is meant for the tracks not the streets. Race wisely.
    You might have encountered brake overheat. Do you have the vented discs? Some brake pads wont grip the discs if they are extremely hot. Actually it was good for you that the brakes loose a grip better than locking the tires and spinnig you out fo control. You may have a racing setup for speed, but did you also customize your brakes?
    Just a thought. :D
    check your brake pads.. baka nde nya na kaya pahintuin ang kotse mo coming from high speeds.. at slow speeds kasi madaling magpreno. kahit upod na pads.. pero at high speeds.. wala talaga.. kahit nakatayo ka na sa brake pedals mo.. dire-diretso lang takbo mo...
    drag ba yan tipong straight line or "stop and go" harurot with lots of swerving? :mrgreen:
    iinit din ba yung disc kung d ka naman masyadong nagprepreno?
    baka may bubbles sa brake line mo. try mo ipableed.
    meron ka bang abs? Did you "slam" on the brakes? Weird kasi feeling ng abs esp pag d ka sanay.
    Check mo hoses near the master brake cylinder, it may have popped loose.
    [size=18]tsk tsk tsk!!!! [/size]
    Iho delikado yang ginagawa mo! :x Eh kung makapatay ka, ano ka na? Manslaughter ka automatic dahil sa walang kuwentang kakakarera mo!
    [size=24]RACE THE STRIP NOT THE STEETS!!!!!!!![/size]
    ayan! napagalitan ka tuloy ni papa PK!
    Quote Originally Posted by kupaloo
    nagulat ako ng humataw ako.
    kinarera ko kahapon yung corolla.
    pag dating sa trpik pepreno na ako biglag nawala.
    tumigas pero medyo kumagat din ng konti.
    bakit kaya nagkaganun?
    pero ngayong umaga balik na ulit ang preno.
    depends.
    it could be:
    -brake pad overheat (happens to me often bec of my driving style)
    -air in your brake line
    -brake fluid overheat
    -brake pads too cold (if you have racing brake pads)
    -low brake fluid level (very low)
    -you were stepping on the gas AND brake. hehehe
    Have your brakes checked. Just remember mas mura magpagawa ng brakes kesa magpalibing. :wink:
    ok mga sir di ko na po uulitin pero kinabahan talaga ako dadalin ko na din po sa mekaniko to be sure pero sa tingin ko overheat nga ang pads dahil sa highway kami nagarangkadahan e bali wala lang ako magawa nung pauwi na ako para lang nainip siguro ako tapos may kotse na bigla ba namang sumingit sa akin at pinaharurot ang auto niya kaya siguro uminit ang ulo ko pero di ko na po uulitin well salamat po sa mga advice ninyo sa uulitin!!!!
    Nangyari na sa akin iyan. I was not racing at that time pero mabilis ang takbo ko and the FX beside me lost control and swerved into my lane.
    The culprit was the vacum assist for the brake system. Biglang tumigas yung pedal from right under my right foot. Akala ko tuloy brake failure.
    When your vacum assist fails, it does not mean your brakes have failed. Nawala lang yung power assist niya. Parang power steering failure ba. You still have the same braking power but you need a helluva lot more muscle to fully utilize, it.
    Jan 2003
    sakin din nangyari na yan pero ang cause is--- tingin ko nangibabaw lang init ng ulo ko over sa presence of mind ko sa pagdadrive... :wink: pero pa-check mo na nga yang auto mo...
    ingat ka pare sa susunod!
nawalan ng preno ng nakipag karera ako!!!
