Results 1 to 7 of 7
- Dec 2007
- 7
December 17th, 2007 10:23 AM #1nabinili ko na.
http://tsikot.yehey.com/forums/showthread.php?t=45200
ano ang maibibigay ng tune-up? maganda ba magpa tune up sa shell o
sa goodyear (las pinas). may magagawa pa ba para tumahimik ang 1st
gear ko.
December 17th, 2007 10:44 AM #2
mas detailed ang tune-up sa servitek las pinas bro compared sa mga shell stations. but if you would want it be done perfectly, try to visit Mc Clain Motors at space 3-4 Motortown, ATC. (Contact: 809-6040). Pati injectors mo lilinisin nila and papalitan lahat ng tune-up related parts na dapat palitan (e.g. fuel filters, plugs, air cleaner).
experience ko kasi sa shell, pag hindi mo sinabing palitan yung air/fuel filter, hindi ginagalaw eh.
- Dec 2007
- 7
December 17th, 2007 06:09 PM #4
congrats sir!
ganun din nga experience ko kahit sa ibang shell station pati petron
December 17th, 2007 07:03 PM #5
Congrats bossing sa new ride mo! Eniweys pa check mo na rin suspension system ng bagong ride mo aside sa engine.
December 18th, 2007 10:50 AM #6
congrats. madali i-maintain yan. hindi kalampagin and kung may problem man ay madaling patinuin.
in time you will learn na a lot of things can be done by yourself, diy maintenance.
look into replacing the following: air filter, fuel filter, spark plug, oil and oil filter of course, drain and flush radiator coolant and replace with new one. see if thermostat is installed and working if not replace it with a new one. clean carb with carb cleaner. replace mo na rin condenser ng distributor.
check and replace all hoses na medyo matigas na.
how about the timing belt? when was it replaced? (this is a crucial one) consider having a new one together with cam and crank oil seals and water pump.
if the former owner can show you that it was casa serviced indeed and replacement of timing belt was done according to sched and all receipts of work done by casa is with you. then, you dont have much of a problem. otherwise, follow the above. if budget is an issue, focus muna sa timing belt and the basics like all filters and oil replacement.
maganda pasko natin hahLast edited by Asus700; December 18th, 2007 at 11:04 AM.
- Dec 2007
- 7
December 19th, 2007 05:28 PM #7Salamat ulit. magpopost ako ng mga pics at yung mga nagastos ko. merry christmas.
Shares of Toyota, Mazda, Honda, Suzuki fall after safety scandal | CNBC New safety scandal just...
Shares of Toyota, Mazda, Honda and Suzuki fall...
