Results 11 to 20 of 71
- Oct 2015
- 922
October 23rd, 2015 01:17 PM #11Mahal na tuition nga yan.
Pansin ko lang madalas nakaka bili ng best buy na auto e mga 2nd hand car dealer din, kasi sila unang aalokin ng mga mabilisang binta,
- Aug 2015
- 220
October 23rd, 2015 01:20 PM #12Anyway, expect things to repair talaga pag 2nd hand cars. Part ng wear & tear talaga yan ng aging mechanical moving equipments kahit gaano kaingat pa ang 1st owner sooner or later may lilitaw na problema. Kaya nga dapat din talaga i consider ng isang taong nagbabalak bumili ng car ke brand new o 2nd hand ang financial capability nya for keeping it.
October 23rd, 2015 01:47 PM #13
October 23rd, 2015 01:47 PM #14
Certified MB Addict
- Apr 2007
- 2,284
October 23rd, 2015 01:47 PM #15
October 23rd, 2015 01:49 PM #16
based on experience, yes. mas ok bumili sa dealers.... the worst thing they can do lang is to tamper your odo. pero kung titignan mo, ganun pa din, you will never know the condition of your engine's innards until it explodes in your face. unless during vehicle inspection, bubuksan mo talaga makina.
kung afford pa rin talaga, mas ok pa din kumuha ng brand new..... talo talo na lang sa depreciation.
October 23rd, 2015 01:49 PM #17
October 23rd, 2015 01:52 PM #18
October 23rd, 2015 02:12 PM #19
Mazda 323 1994
Acquisition cost 70k
Mga pinaayos at pinapalitan during for the past 4 years:
1) 4 brand new tires na Kumho Solus 10,500
2) Cv joint right side and labor 4k
3) Replacement of the ac condenser, evaporator, compressor magnetic clutch, belts, condenser fan motor and extra fan plus labor 25k
4) 4 pcs shock absorbers plus labor 12k
5) Full engine overhaul and replace crankshaft, timing belt, and valves 25K
6) Replace rear wheel bearing left side 4k
7) Brake components and repair kits 4k
8) Replace hydrovac and clutch master 15k
9) Radiator repair 1k
10) Replace shifter bushings and crossmember bushings plus labor 2,500
11) Change oil parts 1k
12) Battery 6k
13) Installed grounding kit 500
14) Sony xplode head unit and pioneer speakers 8k
15) Carb repair 3k
16) Replace valve seals and top overhaul labor 12k
October 23rd, 2015 02:20 PM #20
17) Replace crankshaft pulley and waterpump 10k
18) Replace spark plugs 600
19) Replace air filter element 300
All the lessons learned sa repairs nito was my baseline in choosing the Ertiga as the replacement ca
Better get the diesel po instead of gas version. Aside from better FC, medyo mas less headache...
Kia Sportage 2014, worth it?
