Results 11 to 17 of 17
April 21st, 2011 03:34 PM #11
AFAIK pag diesel, hindi daw madaling mamatayan kumpara sa Gas. Hindi ko pa nattry sa diesel ) tska sanayan lang daw yun, pero hirap tlaga ako kasi bago lang ako sa manual. ganun daw tlga. practice make perfect ika nga.
eh ang mga kotse pa naman ngayon sobrang sensitive ng clutch. kumpara sa mga luma grrr
April 21st, 2011 03:40 PM #12
- Apr 2009
- 311
April 21st, 2011 05:20 PM #15di talaga madaling mamatayan pag diesel, kasi pag binitawan mo clutch ng gagalaw na agad aalalayan mo nalang sa gas
- 52,731
April 21st, 2011 08:53 PM #16practice lang, bossing. clutch replacement is still cheaper than bangga. clutch is designed to be replaced regularly. abuse your clutch if need be, and avoid the bangga! you'll learn the trick eventually, despite all the confusing advice we write here..
high idle RPM at engine start
