Results 1 to 10 of 15
September 10th, 2007 04:46 AM #1
sa mga eksperto sa sasakyan,
say for 15years, no accident happened, how can you tell when your airbag will still deploy??do we need to replace it or the casa has some sort of tester??
September 10th, 2007 06:52 AM #2
I'm not an expert, but from what I know ...
Depending on the manufacturer, they should last 10-15 years. Whenever you start the engine, the ECU diagnostics include the SRS. If it doesn't find a fault, it will deploy when it has to. Whether it will deploy properly inflated or not (due to material degradation) - is the reason IMO why airbags have a lifespan.
Zombie
- Aug 2006
- 728
September 10th, 2007 06:53 AM #3usually they just use an ECU scanner to check if there is a fault code. Minsan nababangga ka pero kiss lang, hinde sha magde-deploy pero pag pinacheck mo sa ECU may error code. Ire-reset lang yun, pag nabura ok na, pag hinde nabura then that means there's something wrong.
September 10th, 2007 08:14 PM #4
September 10th, 2007 08:28 PM #5
ayaw ko nasa isip mo automahn, masakit (katawan at bulsa)
ano ba talaga life span ng mga airbag??ok, granted 15yrs ang life span, pano naman yong mga sensors nito and mga magkano kaya replacement??Last edited by VtEC; September 10th, 2007 at 08:32 PM.
September 10th, 2007 08:46 PM #6
tignan mo yung sa sun visor (ito ba tawag dun)? mo sa taas ng driver side may parang manual dun na nakadikit na sinasabi: children below 5 years old should not seat in the front passenger side, tapos yung last sa listahan is nakalagay na kapag hindi nagamit yung airbag in 10 years time, have it check sa casa and every year there after.
September 11th, 2007 12:44 AM #7
You can have it checked through your vehicle's diagnostic port when you're at the dealer. Annual checks start when your airbags reach 10 years old.
Otherwise, there's not much you can do. The parts of the airbag system are mostly durable (the contacts are even gold plated). The explosives are inert when separated. There's really not much that can go with them. And if something does, the warning light will illuminate.
September 11th, 2007 12:50 AM #8
ganyan talaga basta more than 10years old na sasakyan, you wonder if some parts will just give up such as the airbag...yan kapalit ng depreciation na advantage sa 2nd or 3rd hand buyer
September 11th, 2007 12:14 PM #10
Look for an abandoned wall...you figure out the rest
Chances are it should work, since airbags aren't made by the car manufacturer but a separate company. Airbags from an S class MB w126 still worked, and those are 20+ years old already.
Since yung spare tire nasa labas ng sasakyan. Ano tawag dun sa lock na nilalagay sa spare tire para...
