Results 1 to 15 of 15
    sa mga eksperto sa sasakyan,
    say for 15years, no accident happened, how can you tell when your airbag will still deploy??do we need to replace it or the casa has some sort of tester??
    Sep 2005
    I'm not an expert, but from what I know ...
    Depending on the manufacturer, they should last 10-15 years. Whenever you start the engine, the ECU diagnostics include the SRS. If it doesn't find a fault, it will deploy when it has to. Whether it will deploy properly inflated or not (due to material degradation) - is the reason IMO why airbags have a lifespan.
    Aug 2006
    usually they just use an ECU scanner to check if there is a fault code. Minsan nababangga ka pero kiss lang, hinde sha magde-deploy pero pag pinacheck mo sa ECU may error code. Ire-reset lang yun, pag nabura ok na, pag hinde nabura then that means there's something wrong.
    Aug 2003
    Quote Originally Posted by VtEC View Post
    There's only 1 way to find out... Hehehe.
    Pero mahirap nga yan. At least yung ABS matetesting mo, itong airbags magtitiwala ka na lang sa mga warning sensors nya sa dash mo gaya ng nabanggit nila.
    ayaw ko nasa isip mo automahn, masakit (katawan at bulsa)
    ano ba talaga life span ng mga airbag??ok, granted 15yrs ang life span, pano naman yong mga sensors nito and mga magkano kaya replacement??
    tignan mo yung sa sun visor (ito ba tawag dun)? mo sa taas ng driver side may parang manual dun na nakadikit na sinasabi: children below 5 years old should not seat in the front passenger side, tapos yung last sa listahan is nakalagay na kapag hindi nagamit yung airbag in 10 years time, have it check sa casa and every year there after.
    You can have it checked through your vehicle's diagnostic port when you're at the dealer. Annual checks start when your airbags reach 10 years old.
    Otherwise, there's not much you can do. The parts of the airbag system are mostly durable (the contacts are even gold plated). The explosives are inert when separated. There's really not much that can go with them. And if something does, the warning light will illuminate.
    Dec 2003
    ganyan talaga basta more than 10years old na sasakyan, you wonder if some parts will just give up such as the airbag...yan kapalit ng depreciation na advantage sa 2nd or 3rd hand buyer
    Mar 2007
    pwede kaya itesting? hehehe
    Jul 2006
    Look for an abandoned wall...you figure out the rest
    Chances are it should work, since airbags aren't made by the car manufacturer but a separate company. Airbags from an S class MB w126 still worked, and those are 20+ years old already.
    yeah, usually the ABS sensor on your dashboard will light up if something's wrong with your airbag. unless of course someone's tampered with your sensor...
    Sep 2006
    Quote Originally Posted by Automahn View Post
    hehehe eto din naiisip ko eh
    electronic type airbag systems have an indicator in the dash, but some mechanical type airbags don't. ganito yung driver side airbag ng ae101 corolla Gli (96-97). paano kaya malalaman if it still works or not? (except yung obvious na paraan) hahaha
    You won't know if the airbag will work until you'll need it. For now, just pray that it will work.
    hope and pray indeed.anyways, madaming salamat po sa mga inputs.
    OT: FYI; just incase lang..yellow corrugated tube is usually used to mark the harness of the airbag.
how to know if the airbag is still working??
