Page 1 of 2 12 LastLast
Results 1 to 10 of 20
    Feb 2007
    Just got my Honda Civic 2.0SL Nighthawk Black this week complete with the Paddle Shifter -- Wohooo!!
    Any info on the detailed specs of the engine ?
    Jun 2006
    Wow! congrats to your new ride . kakainggit! grabe ang ngiti mo sa pic sa dulo ah, hehe.
    2.0 DOHC 16V I4
    Maximum Output (bhp * rpm) 155 * 6000
    Maximum Torque (Nm * rpm) 192 * 4200
    Fuel Type / Recom. Octane Gasoline / 95~
    Fuel System / Aspiration i-VTEC, EFI / NA
    Sep 2004
    Aug 2004
    152 hp... supposedly dynos at 125-130 whp on the rollers, which is terrific for an AT car. (mine dynos at 132-137... still going to confirm when I get my mods done).
    Lacks a little torque, but really lively once you get it revving. Love the paddle shifters, as they'll let you do things most manumatics won't.
    Aug 2005
    K20A3? still? it should've been the true K20A (type r) by this time right? i don't know why HCP doesn't want to bring in the true blue K20A or at least the K20Z3 (Si)
    Feb 2007
    What is the difference between the K20A and K20A3 ? From the pictures they look the same. Is it tuning ? They are both 2.0 liter engines with almost the same parts. Or is it just the ECU ?
    I am still experimenting with the paddle shifters cuz i am still heavily dependent on the the shift indicator found at the lower display. One fundamental flaw was they did not put the shift indicator on the upper display where it is much much easy to look at if you want to keep your eyes on the road.
    Aug 2005
    It's not just the ECU and Tuning differs the K20A VS. K20A3.
    If that is the JDM civic engine (non type r) then it is a K20Z2 it's the same as the K20A3 where the ivtec system is "only" on the "intake" cam and functions as a 12 valve engine when on low rpm mode and opening only one intake valve so that the air swirls for better combustion. The ivtec system on this engine is dedicated to fuel economy in mind. Unlike the K20A/A2/Z1/Z3/ the ivtec system allows the motor to run in 16 valve mode all the time and when it engages, its on both the intake and exhaust rockers, and opens all 4 valves even more at high RPM.
  9. #9
    e ung sa UDSM na FD-SI, anu difference sa specs ng engine nun over sa local nating k20a nanakaabit sa local nating FD??
    (aside sa 6-speed manual tranny and red guages w/ SI printed on it...)
    yung us na 2.0
    197hp*7800
    redline is 8000rpm
    ang laki yata ng deperensya
PHOTO-OP with the K20A
