M-Y-T-H!
Here's our Tsikoteer mythbuster at work:
AFAIK - more than 5 hours naka idle lang ang engine while the exhaust is submerged in water.
To note also, in order to maintain that "high rpm level", you need to use your clutch.
And using your clutch when crossing floods / water should be avoided as much as possible!!!
The engine at idle already has enough pressure to keep water out of the exhaust.
