Results 1 to 4 of 4
February 4th, 2016 10:18 PM #1
Good evening guyz...
Ask lng kung normal b ung dripping sound under the car..?.say the sound came from under the front seats...
I checked if there is leak on the garage floor pero wala nmn...
Ung sound nya kasi ay parang may tumutulong tubig sa empty na stainless planggana.. And or sounds like nagiinit ka ng mantika then u put 1 drop of water on a boiling cooking oil. But afyer a few minutes, say 3 or 5 mins, nawawala na nmn...
I suspect kasi na baka dahil lng mainit ung makina... Lancer po ito... 2.0 engine... 91 RON recommended fuel.... And i always use 95 RON...
Thanks..
February 5th, 2016 06:48 AM #2
Late model cars use either stainless steel or hot rolled high strength steel (HSS) for the exhaust pipes. When you shut the engine down and the exhaust temperatures are high, it makes dropped uling sounds as the metal shrinks back to size
- Oct 2015
- 175
February 5th, 2016 09:05 AM #4
Before the power run both filters are already primed so pre-fill should no longer be an issue, but...
Thick (20W-50) vs Thin (5W-20) Engine Oil Tested
