Results 11 to 20 of 30
November 25th, 2007 04:26 PM #11
+1 to message above. make sure you have your insurance signed, last will written, your girl scored, etc if you're planning to do it on public road. make sure you limit the casualties to yourself if you do.
November 25th, 2007 05:13 PM #12
Be really careful when flooring it mid-turn when the road is wet. I did this one time and my car downshifted to the next lower gear, the rear wheels spun, and the tail flipped out. Good thing the car had good balance and I countersteered as I exited the turn.
So there came a time when it was once again rainy, late at night and nobody was around. The left arrow was green and I had good momentum. Needless to say it was probably weird to see a diesel drifting in the rain making a corner. Buti walang pulis
November 25th, 2007 05:24 PM #13
well, i sometimes brake lightly when tackling medium to slightly sharp corners. pero slow speed na ako nun, around 20kph na ata, basta nasa 2nd gear speed lang.
pero pag yung mga wide corners or highway corners, i just lift my foot off the gas way before the corner to slow down the car.
pag straight na yung car, saka na lang ulit ako umaapak sa gas.
car is a fwd with abs, btw.
November 25th, 2007 06:22 PM #15
hmmm... well if you feel that your car is understeering, try brake drifting then countersteer a bit if the car's rear is already "floating". now i'd wish i have 4 wheel steering in my car.
- 370
November 26th, 2007 09:47 AM #16It is better to brake in a "straight" line.
The straight line may not necessarily the path the road takes.
Braking in a straight line maximizes the grip potential of all 4 tires and provides the most predictable braking characteristics.
Trail braking(braking while cornering) is a more advanced technique which drivers of higher skill employ when they are going into a corner too fast. It requires you to ease off or modulate the brakes while going into a corner.Last edited by Auto_Xer; November 26th, 2007 at 09:55 AM.
November 26th, 2007 10:51 AM #17
For us (well most of us) na non-racers, our safest practice (during high speeds) is to brake before the corner not during the corner.
- 102
November 26th, 2007 02:19 PM #18it is possible to brake and corner at the same time. what matters is the degree at which you will take it. a normal car has in approximation about .7 to .8g of grip which applies to both braking and cornering. the trick is how to share this available grip to both variables. if ur braking at .8g and you try to turn the steering wheel, like when ur entering a corner and you maintain the same pressure on the brakes, you will either spin out or understeer depending on your vehicle's configuration. if you're cornering at .8g and you apply .3g of brakes, you will get the same result. if ur cornering at .6g, then it is possible to make minute adjustments to your speed by applying your brakes, but no more than .1 or .2gs of braking and you will not spin out. the fastest way through a corner is by trail braking (at least in circuit racing), where you burn off excess speed by max braking before entering a corner, then trail off the brakes as you pick up the cornering forces simultaneously. to give you a better idea of g forces, the amount of strain on your neck while lying on your side with your head off the bed is exactly 1g
November 26th, 2007 03:11 PM #20
Understeer - you hit the tree headfirst.
Oversteer - you hit the tree buttfirst.
Daming issue ng SU7:grin:
Xiaomi E-Car
