Results 31 to 40 of 41
August 1st, 2006 01:44 PM #31
Australia used to build V8 engines for their Holden vehicles which are now supplied by GM. Witness V8 in pure action in Aussies' V8 Supercars and US NASCAR. More valves or cylinders mean more mulah. You can get equivalent and cheaper results with a forced induction engine just by adding a supercharger unit. Although NA engines for me all the way baby.
August 1st, 2006 01:53 PM #32
so anu purpose/advantage na having power on the mid to top end kaysa sa having power from low-mid end...
August 1st, 2006 01:58 PM #33
well having power on the mid-range is thought to be most efficient for fuel consumption. you see, more speed means more fuel spent. having power at mid-range has considerable effect- balance between fuel efficiency and power.
August 1st, 2006 02:37 PM #34
hmm..pero sa power, anu naman ang effect? civics are know diba parang "mahina humatak sa trafic" because of mid-end max torque, unlike ung others na 2000-400 ang max torque....
August 1st, 2006 02:53 PM #35
Originally Posted by alwayz_yummy
although the newer i-VTEC (4-cylinder) engines has already addressed this by introducing a variable cam timing (regardless of engine speed) on top of the existing VTEC system. the i-VTEC V6 can shut off 3 cylinders when cruising below 80kph.
August 2nd, 2006 07:26 PM #36
Originally Posted by ian_rex
but anyways.. salamat sa informative answer mo. keep it up!
August 2nd, 2006 11:10 PM #37
August 2nd, 2006 11:12 PM #38
Originally Posted by rsnald
August 3rd, 2006 12:30 AM #39
August 3rd, 2006 05:45 AM #40
Originally Posted by Helios
That's why hindi lang basta-basta salpak turbo sa 4g63, naging Evo na.
Yung 4g63 ng evo, among other things, reinforced cylinders & pistons nun... kaya mahal.
Ah ok. So Wala pa Lang locally released na delicą dito. Pinapakyaw kasi Ng mga outdoor lovers...
Mitsubishi Philippines
