Page 1 of 2 12 LastLast
Results 1 to 20 of 30
    I am restomoding my brother's 1969 Mustang fastback simultaneously with my Eleanor.
    It is currently sporting a plane Jane 302 4 barrel engine as seen from the picture below.
    http://www.flickr.com/photos/81856035*N00/391856551/
    Below is a set-up I am working on to replace the engine. The new set-up will have a 2 barrel Cleveland head and a custombuilt intake manifold. The Cleveland head has been modified to accept the 302 block. This is called a "CLEVOR". It is the base of the BOSS engine.The intake manifold is a Hi-rise, open plenum, air-gap design. I personally fabricated the manifold from scratch. This conversion manifold has been out of production for a long time from the US market. So, my only option is to make one. As for the Cleveland heads, it has to be drilled to accept the intake manifold water passage and head-manifold water passage, and two of the heads water port has to be closed-shut.
    http://www.flickr.com/photos/8185603...n/photostream/
    Below is the old power steering unit(for sale), and the Dodge Intrepid Rack and Pinion unit that will replace it. This is the best unit(same as Unique Performance) for a V8 because of the large tie rods that will turn large tires!
    Below is the 13" cross-drilled, slotted, and ventilated front rotors. It will be stopped by a 4 piston caliper from a Lincoln Continental.
    Down rear has a 9" 3.5 gear to be stopped by 11" cross-drilled, slotted, and ventilated rear rotors. to be stopped by 2 piston caliper from a Granada.
    The engine will have a set of 10:1 Clevor pistons, 280 roller cam and lifters, 780 Spread bore dual pumper Holley. Mallory Unilite distributor, Mallory hyfire and coil will take care of the ignition.
    Tires are 225/50/17 front and 255/40/17 rear.
    The car will have front and rear spoilers, new set of chrome moulding and chrome grill surround.
    Interior will be restomoded to a 2 seater.
    The Clevor engine is a 302/351 Windsor engine that is topped -off with a set of Cleveland heads(2V or 4V).
    For the street, the 2V version of the Cleveland head is best(this is what I am using for my brother's FB). Using the 4V on the street will be sluggish, because the intake/exhaust runners and valves are so huge that the air velocity slows down that the fuel separates from the air. If you are to use a 4V head, have your rotating assembly balanced and instal 4 bolt main caps. Kasi a BOSS clone with 4 V must hit 9000rpm for maximum efficiency.
    Use also dampened valve springs because 9000rpm will disfigure a valve spring.
    The regular 302 pistons will not do because the valve reliefs are in different position. The large 2v head valves are in splayed arrangement.
    The 4 bolt main caps are necessary for the 9000 rpm runs(kala nyo Honda lang ang may kaya ng 9000rpm, 1960's pa ginagawa na ng Muscle cars, push rod engine pa!).
    Dual point distributor pa ang gamit ng Boss, Mallory Unilite ang gagamitin ko.
    All in all, simply lang ang gagawin ko sa FB ng kapatid ko.
    Salamat Kuya!
    Hi Bunny!
    Kamusta na Mustang mo?
    Meron akong bagong dating na alternator. Mataas ng konti sa rating mo. Hehe.
    Newly painted. Still candy apple red. New weatherstrip (the whole car!).
    I'm broke but happy.
    Aircon na lang problem. Di na malamig. Kaya mo ba?
    Yung pinsan ko ang gumagawa ng A/C.
    Mahusay naman, inayos yung 350SL ko dati, malamig!
    Mar 2004
    Mr. Turbo! Idol!!! ang galing mo naman sa kotse... where did you learn all that sir?
    sana post ka naman pic nang mustang mo pag tapos na...
    sana matuto din ako nyan.... nagkakarera ka ba boss?
    panay EFI na kasi inabutan ko... gusto ko din matutunan ang carbs boss
    Zdre,
    Malakas lang ang loob ko, kaya nagagawa ko ang gusto ko.
    Madali lang ang carburated engines. I you want to learn, you are always welcome here.
    Medyo matagal pa matatapos amg FB.
    Sa mag nakakaintindi ng EFI ako naiinggit. Di kasi ako sanay sa EFI. Too much electronics and too many complicated things that can go wrong.
    Thanks for the complements.
    Apr 2005
    ganda naman nyan koya turbo and the technical know-how
    pa-post din nung buong body nung mustang para mas ma-appreciate!
    buti pa si bunny, broke but happy....ako, broke lang...
    Ok, I will be posting some pictures soon.
    The installation of the rack and pinion steering is complete. Took us 3 days to complete it from scratch.
    My brother just left for US for a 2 week vacation. As soon as he comes back, I will pull out the 302 for reboring to accept the 0.040" pistons, resurface of the deck, align boring for the 4 bolt main caps.
    Then install the roller cam and lifter. The Cleveland heads will be rebuilt with Stainless steel valves and bronze valve guide.
    I will do the porting and polishing myself.
    Then it will be mounted on an engine stand and run for break in. I am still scouting for a toploader.
    Feb 2006
    Boss turbo, baka makadaan ng Reno si bro mo... may pauwi lang, ehehe...
    you are really the man sir turbo! carry on sharing your wisdom....
    For the Muscle car lovers, I can give free classes on Muscle cars every Saturday, pero dito lang sa Bocaue.
    That is if you trust me, hehehe.
    Marami din akong DVD na pwede nyong panoorin while here.
    May maliit akong Home theater na pwede natin panooran and if you want hands on practice, I will let you sweep the floor, hehehe.
    I can let you work on an engine for practice.
    Sana I am worthy, baka mas marunong pa kayo sa akin. hehe.
    Aug 2005
    Quote Originally Posted by turbo View Post
    W*W! totoo po? im a willing student!
    Yes, once a month.
    Para na ding get together.
    May school kami, pwede yung mga class rooms.
    Mar 2004
    wow... san po loc nyo sir ?
    ok lang kahit mag sweep ako floor or taga pihit turnilyo
    Malayo lang kami.
    Bocaue Bulacan pa.
    I can make you do OJT, pero unpaid hehehe.
    Mar 2004
    sige oks lang po... how to get to your place?
    Go to NLEX and take Bocaue exit.
    Turn left towards MacArthur hiway.
    Go straight ahead until you get to MacAthur, then cross the hiway under the fly over.
    Proceed until you reach a white house, it is just 100 meters away from the fly over.
    Mar 2004
    thanks a lot sir
1969 Mustang Fastback
