Page 2 of 2 FirstFirst 12
Results 11 to 16 of 16
    Jan 2009
    I'm with ^. Excessive tire wear is not necessarily a problem on the tires themselves. Structural integrity (up to a certain extent) and trueness is.
    There is no adjustment to be had with a beam axle, but it would be interesting to see what the readings are.
    I recall some Focus owners were complaining about poor rear tire wear due to the built in camber. We didn't have those issues on our dear, departed (sold! Wahhhh!) TDCi because the front tires wore down to nubs, first.
    I think its the stock 1.5(?) degree negative camber of the Focus' rear suspension is a bit too much though, the inner part of the wheels tend to wear out faster.
    Treadwear rating for the Eagle NCT5 is 240, while the Assurance Fuel Max is 280, based on what's written on the tire (though in online sites it says 580).
    It should at least last a tiny bit longer, the only problem I had with the Eagle NCT5s is they wore out fast.
    I'm just curious what the (permanent) camber setting is on the Fiesta's twist beam rear suspension.
    PS: What is the Treadwear rating on the Fiesta's OEM Continental tires?
    Dec 2010
    Another nail to seal Continental's coffin:
    The tires stayed swapped 6 months, approx. 10,000 KM causing the mysterious noise. When they were swapped back, the tires that stayed in the rear suspension were OK in front.
    By logic, that eliminates the theory that suspension is the culprit.
    Here is a picture of the Fiesta's rear suspension :
    Link : 2011 Ford Fiesta SES: Suspension Walkaround
    This confirms my understanding that the rear tire is just there for the ride. Add to this that most of the duty of our fiesta is to carry only the driver. Wala usually load sa likod kaya we cannot theorize mas bugbog yung rear tires.
    It was simply defective as it was manufactured. Conti meet Moto. Hello Moto!
    Feb 2005
    Just to check, there is no warranty violation as long as we use the same dimension tire right? Also changing the stock rim to another similar size should not affect the warranty?
    would going to a 205/55r16 be ok? anyone on that size?
    Quote Originally Posted by LoBudget View Post
    On a Fiesta? If its for a Fiesta, that might be too big.
    16's for the Fiesta Sport is 195/50R16 (23.7in diameter).
    205/55R16 = 24.9in diameter
    Dec 2010
    *3GEMS
    Eto sya...
Palpak : Fiesta Continental Tires
