Results 1 to 2 of 2
- Jun 2013
- 1
June 15th, 2013 11:02 PM #1hi,
i'm a super new driver and not so familiar with the car industry esp with pre-owned cars. is 220k reasonable for a 3rd hand ford lynx ghia 2005 model? help please
thank you in advance
- Jul 2013
- 27
July 10th, 2013 04:14 AM #2That depends. The Ford Lynx is a good design. It's a rebadged Mazda Protege/323.
What's the mileage? Condition of the engine? If it's an automatic, does it shift properly? What's the condition of the interior?
It might be easier to look for a used car check list. The list would give you more systematic way of ensuring that you don't get somebody else's problem.
Here are my suggestions on checking out a used car:
1. test drive - drive it at 100 kph for at least 5 minutes. If the steering wheel vibrates, the car needs to be realigned at the very least. It might have some expensive suspension problems too.
2. use a check list - there are a number of used car check lists on the web. Use one that you understand. I saw a Popular Mechanics pdf check list on the web. It looks pretty user friendly and it also gives you some tools that you might want to bring.
3. have a trusted mechanic inspect the car - this is probably the most important one. Have the mechanic check the underbody and the suspension. If the car was flooded, there will be telltale signs.
220k for a For Lynx sounds reasonable based on the For Sale listings on this site. However, you have to make sure that you don't get a car that will fall apart on you the very second you hand over your money.
Good luck!
just did a quick search... BYD e6 - Wikipedia Yung 1st Gen BYD e6 pala was released in 2009...
China cars
