Results 431 to 440 of 720
- Dec 2002
- 2,335
February 21st, 2011 12:52 AM #431just to share my comments/opinion on improving the lighting performance on your Fiesta.
If warranty is no.1 priority then do not do a retrofit coz for sure you will lose the warranty.
If lighting performance is no.1 priority then do an hid projector retrofit. Hands down this will beat any halogen bulb or even the Euro spec halogen projectors. Even if you mount HID bulbs on these headlamps.
I have yet to see a halogen projector that can even come close to the performance of an HID projectors and I've seen many. A complete hid projector retrofit is way cheaper than the Euro spec headlight and the looks will come really close to oem.
But you can actually get the best of both worlds. Improve lighting performance and not lose your warranty. Get an aftermarket headlight and retrofit this. The harness and mounting of ballasts can be done oem style, as in the whole HID syst is mounted on the HL and no splicing of the harness will be done. This way if ever you claim warranty it is so easy to use your stock headlights. This is in no way suggesting to fool the casa since if the harness is done properly and the retrofit is designed and executed properly, it will in no way affect the electrical system of your car.
Ganito I think yung Euro spec na headlights right? Close sa look ng Focus RS yung shrouds.
February 21st, 2011 12:57 AM #432
That post was well worth your time and effort. Me not an audio guy like yourself will take your advise and NOT upgrade them anymore, contrary to my earlier plans. Mga below 5K din balak ko and I also think the stock ones are great. Ang trip ko kasi is audio books while driving. Driving is a bonus free time to learn more about anything under the sun, specially my line of work.
5K will go a long way towards my other future mods .
Again, many thanks in the most sincere sense of the word.
February 21st, 2011 01:09 AM #433
Yes I vaguely recall a retrofit done with the slim type ballast placed inside the housing. I understand HIDs consume less wattage but throw greater light so burden on the existing wiring in terms of Amps is less.
I've done the "devil eyes" mod and noticed that space within the housing is plenty plus extra space on its "belly".
Here is my question Sir: How much would a retrofit cost? Please give a range from the cheapest to the most sophisticated.
Have you done a Fiesta already?
- Dec 2010
- 191
February 21st, 2011 02:03 AM #434
February 21st, 2011 05:43 AM #435
- Jan 2011
- 155
February 21st, 2011 09:02 AM #436* anti, I also envy your headphones hehehe, so as i have posted earlier, it seems that the stock speakers of the sport is really different from the trend, so if you have a sport, then perhaps it will really be better to stay with your stock, as for trend owners like me, who only have cheapo speakers at the front and none at the back, well, having speakers at the back really makes a big difference.
to trend owners who added speakers at the back, heres my audio settings, ipod nano (via aux) equalizer off, head unit rock, bass mid and treble dependent on song ( free mp3's kaya iba iba ang volume level hehehe ) then set your dsp to concentrate on driver, and it brings the sound up front.
- Dec 2010
- 191
February 21st, 2011 09:32 AM #437theres a high chance that the speakers of the trend and the sport are actually the same minus the rear speakers. the sport stock speakers are also cheaply made. paper cones and very very light.
baka iba ng konti yung output of the head unit thus making it sound different. it can also be that its the same with a few missing settings like the fader which was mentioned somewhere here. then just a lack of rear fill from the rear speakers.
if someone upgrades the trend's front speakers let me know. lets compare pictures of the stock speakers so we can know once and for all if they are different.
or maybe some of us here can compare the actual sound. trend vs sport. the sport should have the rears turned off via the fader so its an apples to apples comparison. stock vs stock... front only. also use the same ipod, same songs, and same settings.
- Dec 2010
- 191
February 21st, 2011 11:54 AM #438just an update... di ko na kinaya. decided to have an amp installed at mickeys. they are setting it up right now. will just go back for my car later.
cost was about 15k including installation and the converter (not sure) so it will be compatible with he stock stereo which probably doesnt have amp outputs. i got a db drive okur 4 channel amp. wanted the rockford fosgate but it was out of stock at the moment.
A3 80.4
Features:
DRIVESINK heat management system / Buffered pre-amp input circuitry / Continuously Variable 12dB Low Pass X-over / Continuously Variable 12dB Bass boost * 45Hz / Continuously Variable Subsonic Filter (15-55Hz) (Mono Amps) / Direct-connect integrated Speaker and Power wire Terminals / Full Range RCA Line Outputs for easy Daisy chain / RCA configuration / Variable Input Level Control / DC-DC PWM power supply / DC Short Circuit Protection / Bass Remote capability
Specifications:
4 Ω * 14.4 VOLTS: 4 x 80 Watts / 2 x 200 Watts
2 Ω * 14.4 VOLTS: 4 x 140 Watts
1 Ω * 14.4 VOLTS: -
SUBSONIC FILTER: -
CAPABILITY: 2 Ω Stereo
M CARTON: 4
http://www.dbdrive.net/products-deta...es=A3%20Series
will keep everyone updated once i get to listen to it.
February 21st, 2011 12:43 PM #439
Here is the stock speaker of the Trend sedan:
You can compare with the ones taken out from your sport.
As I have said before, like beauty is in the eyes of the beholder, sound quality is in the ears of the listener.
Master is even planning on additional subs for that extra thump .
Me I'm quite happy with mine in the way I use them.
All the audio terms you use sound Greek to me which means I fall outside of the sound guys.
- Dec 2010
- 191
February 21st, 2011 01:14 PM #440will check them later when i get home. actually good sound isnt that subjective. good and bad can be clearly differentiated. the subjectivity comes in when you look (or listen) at how good you want the sound to be... good sound can also have different flavors. meaning some like it with more bass, some, like me, dont.
i prefer good neutral and natural sounding sets. to put it simply... i like listening to music how it was meant to be heard. i dont like adding extra bass to music that wasnt intended for thumping bass.
thats how i chose my headphones... sana ganon din tong upgrade ko with the amplifier.
high idle RPM at engine start
