Results 131 to 140 of 720
- Dec 2010
- 191
January 24th, 2011 09:32 AM #131really need floor mats and i wanna get the 3m nomads... but i like the thought of having them custom cut.
kamusta yung pag cut sa true value? i know they use 3A (nomad like but not 3m) but custom cut is still custom cut.
asked at true value... cost for 2 piece front, then 1 long piece rear seats, plus trunk = 3,799 php yata. anyone tried their custom matting for the fiesta yet?
also... will we void our warranty if we put in a snap on headlight upgrade like the philips xtreme power?
January 24th, 2011 11:05 AM #132
I already have 3M nomads installed in my HB. Just get the smallest size. They are a little oversized, but settle in nicely with a little "lip" around the edge to keep the stones etc off your carpet.
I have also installed Phillips xtreme vision bulbs in my high and low beam, and Osram Nightbreaker plus in the fogs (as Philips don't make a H11 bulb in their xtreme vision series). Noticeable improvement over the stock bulbs for both output and color.
The bulbs are the same wattage as the stock, and you don't mess with the wiring/electrics, so no problems with warranty ...I assume.
Anyway, if one of your stock bulbs breaks, I doubt that is covered in the warranty for replacement
By the way, the stock bulbs are also Philips for high and low, and Osram for fogs....but longer life/lower output version (Cheaper).
- Dec 2010
- 191
January 24th, 2011 11:19 AM #133thanks. can you post pictures of your matting? interested to see how the nomads look before i actually take the plunge (mahal kasi :p) on either the real pre cut nomads... or the custom cut ones at true value.
how much did your lighting upgrade cost? and where did you get them?
January 24th, 2011 12:16 PM #135
January 24th, 2011 12:18 PM #136
- Dec 2010
- 191
- Dec 2010
- 191
January 24th, 2011 02:06 PM #140just bought the oem cargo tray from gerard. searched for "ford fiesta accessories" in sulit as recommended by a post i read somewhere here. 2.7k. havnt installed it yet though.
will post pics after i install it.
heres his link
http://www.sulit.com.ph/index.php/vi...ta+accessories
In my car idle on coldstart was 2k high need 2 to3 mins to be restarted the engine to get the...
high idle RPM at engine start
