Results 7,241 to 7,250 of 7771
- Nov 2008
- 210
September 6th, 2018 10:26 AM #7241
September 6th, 2018 10:29 AM #7242
September 6th, 2018 10:50 AM #7243
Ano na odo reading ng eve mo?
Definitely sa tranny hindi sa engine kasi umaandar naman yung engine. Pag engine oil pump seized up na sana engine mo, or at least totally dead since ecu will shut down the engine with zero oil pressure.
Pag sa tranny, baka putol chain? Or gear? O baka as simple as barado lang filter.
September 6th, 2018 10:55 AM #7244
- Nov 2008
- 210
September 6th, 2018 10:59 AM #7245AT pump is also the torque converter, hindi basta masira ito kasi made of solid material, maybe gasket inside the torque converter ang may sira or the solenoid that controls the flow or sensors.
Sent from my SM-A720F using Tapatalk
- Mar 2014
- 690
September 6th, 2018 11:00 AM #7246How much usually repair cost ng ganyan? Good thing covered ng warranty.
September 6th, 2018 11:03 AM #7247
- Jul 2009
- 3,604
September 6th, 2018 12:11 PM #7248Oil pump daw pero the engine revs but the AT is not engaged. Wala man lang 'thud' when you slot the transmission in gear / the transmission engages?
Seems wrong.
- Jun 2018
- 1,475
September 6th, 2018 12:13 PM #7249
September 6th, 2018 12:17 PM #7250
No thud when in gear but initially the revs wont go up parang naka brake torque yung transmission then after a second or two slippage na (revs without moving forward) and if nasa incline ka aatras yung kotse, effectively neutral kumbaga. Same with reverse.
That pump might be the AT oil pump for the torque converter. Kasi if engine oil pump sira na sana engine ko. Tumambay pa ako sa loob ng sasakyan for at least an hour with ac and engine on before dumating yung montero na rescue car namin. engine seems normal so NOPE its not the engine oil pump.
Sent from my SM-A605G using Tapatalk
high idle RPM at engine start
