Page 704 of 778 FirstFirst ... 604654694700701702703704705706707708714754 ... LastLast
Results 7,031 to 7,040 of 7777
    Mar 2004
    #7031
    Jump start cable is not up to spec ... or the clamps are not tight enough ...
    Oct 2003
    #7032
    Mahal din ng first PMS. Umabot 10K binayaran. No labor fees pa un since free sa first PMS.
    Sana may option na based sa kilometers na lang ung PMS. Lugi sa akin pag 6 months. Haha Aabot ng 6 months ulit wala pang 10K kilometers.
    Oh and mahina na daw ung battery ko. 12.X volts na lang when they checked. Sabi ng service ibalik daw bago mag 1 year para check nila ulit. Kung mahina talaga, papalitan nila under warranty.
    Feb 2007
    #7033
    Quote Originally Posted by zechs View Post
    We're in the same boat bro.
    The car was left unused since April. Finally able to use it again a few days ago. Felt nothing off. The other car didn't start. So far so good with the Eve.
    May 2007
    #7034
    Ano yung speaker sa front door sa taas yung sa window, twitter ba yun? Pano ma test kung working o hindi
    Oct 2015
    #7035
    Quote Originally Posted by eido View Post
    Maybe adjust fade and balance to extreme front left/right then dikit na lang tenga sa speaker to test. HTH
    Mar 2004
    #7036
    Tweeters are on the door beside in the inner part of side mirror ... Twitter is probably in the headunit ...
    #7037
    Assuming you are in stock headunit setup, put the bass and mids to the lowest setting, then increase treble to max settings. The treble settings drive the output of the twitter. Adjust the fade settings to check which side has any sound.
    Dec 2009
    #7038
    Search in youtube a sound test video
    Feed that audio to your cars head unit via bluetooth or auxillary input, then listen to high pitched sound on those tweeters
    Sent from my GT-P3110 using Tsikot Forums mobile app
    May 2007
    #7039
    Yup yung opposite side nga ng mirror yung sinasabi ko. Will do what you guys suggested. Thanks!
    Jul 2016
    #7040
    Hold mo eject button + seek forward button while at AM/FM menu. This will bring out diagnostic menu ng sync. May speaker test function sya. You'll get it once you're there.
    Sync 2: MyFordTouch Diagnostic Mode - YouTube
    Sync 3: 2016 Ford F150 with Sync 3 Navigation program edit and diagnostic - YouTube
Ford Everest 2015
