Page 397 of 778 FirstFirst ... 297347387393394395396397398399400401407447497 ... LastLast
Results 3,961 to 3,970 of 7777
    Jan 2011
    #3961
    Mga sir tanong lang po is it normal parang ang ingay or parang hirap ang 2.2 everest sa arangkada? Antagal mag shift yata ng gear. But pag naka rekta na ang bilis na and very smooth. Ganito po ba talaga ang mga diesel engines? Everest 2016 owner po and this is our first diesel car.
    Thanks!
    Jun 2010
    #3962
    Another view sa mga nag re-request. Opo, nakalabas po sya ng halos 1", Kasi i used +12 offset.
    Sent from my ASUS_T00J using Tapatalk
    Jun 2010
    #3963
    Quote Originally Posted by Unwired View Post
    Thanks!
    Try mo po manual shift (dunno if this is the right term). Try mo release ng konti ung gas para mag shift sya ng gear kubg ayaw mo tumaas ung rpm mo..
    Jan 2011
    #3964
    Quote Originally Posted by gomez_ea2 View Post
    Nagpalagay ka pa ng drl sa ilalim ng fog light?
    #3965
    So i was invited by a research company as one of those to participate in giving feedback being a new owner of the Ford Eve. What would u suggest I highlight as a concern and which aspect to give kudos to? Leg me know so I can be your voice
    Feb 2016
    #3966
    Quote Originally Posted by jabaliza View Post
    For me:
    1. Di pantay contact ng busina, sa bottom part ng steering tama lang pero sa sides ang kailangan extra weight sa pindot.
    2. Alignment ng steering, veering to the right.
    Jun 2010
    #3967
    Quote Originally Posted by megam1x View Post
    For me:
    1. Di maganda quality ng wiper. Di ata ganun kadali mag hanap ng kapali kasi di daw sya hook type (common)
    2. Sa horn, medyo hirap nga pindutin sa side area kaya minsan kailangan ko pa i release kamay ko sa steering wheel para maabot ko bottom part para madali.
    3. Medyo matagal ung shifting ng gear before umabot ng 40kph, mesyo mataas na rpm before mag shift.
    ...Ewan ko kung pwede ito, di pare pareho ang warranty claim ng mga dealers sa everest, like pag nag palit ka ng bagong wheels and tires, sa iba ok lang, sa iba void warranty mo.
    Oct 2015
    #3968
    Quote Originally Posted by VoltsMD View Post
    Finally got my keyring light successfully installed today in Lamson. Same programming as the scuff plate light (where electricals were tapped): turns on when the door opens, turns off when you turn the ignition.
    No more "kapa kapa" in the dark.
    Sir if you do this, will you lose your casa's electrical warranty?
    Feb 2016
    #3969
    Tama ka sa wiper blades, lakas magvibrate lalo sa left, pag binilisan nawawala pero sa normal nakakainis.
    Jun 2009
    #3970
    May token daw na ibibigay anu kaya ito?
Ford Everest 2015
