Page 384 of 389 FirstFirst ... 284334374380381382383384385386387388 ... LastLast
Results 7,661 to 7,680 of 7777
    Oct 2003
    #7661
    Close up shot of the projector with AR coating
    #7662
    Quote Originally Posted by zechs View Post
    Stock HID of the everest is only 25watts and produces around 2000 lumens. Not really "hid". I believe na-consider lang na hid ito is because of the bulb type which is D8S.
    You can "upgrade" the system by changing to a D3S system. Minor adjustment to the bulb holder then you're good to go. Unfortunately, D3S system is also hard to find. Haha
    I've recently tried changing to LEDs which the seller says is rated at 10000+ lumens. Err..will be demoting it to the high beams na lang.
    So logically, step upgrade na to G5 projectors and osram bulbs
    bro, how do i go about this? I just travelled 665 kilometers today from Calamba City to Naga City and back. May tropical storm signal 1 pa kanina. Sobrang hirap yung driver ko kasi ang hina ng ilaw ng everest. grabeh.
    Additionally, saan nakakabili ng replacement windshield wipers po? I went to ACE harware and Handy man, walang katugma yung everest natin.
    Feb 2003
    #7663
    Quote Originally Posted by maillot jaune View Post
    Bro..search mo sa FB yun Everest Garage...nakita ko dun nagbebenta sya ng Silicon wipers for our Eve..inc. yun rear wiper.
    Oct 2003
    #7664
    Marami naman nag-re-retrofit dito sa manila. Sa lipa city meron din ata. Not so sure.
    Feb 2003
    #7665
    Correct there are two known retrofitters right in the middle of your place A bit less 40km going South there’s Chroma Lights. And going North almost same distance is Firedrake...both known quality retrofitters. Pili ka na lang...check their works on their respective FB page.
    #7666
    *zechs & *jiggs
    salamat po sirs.
    Jul 2013
    #7667
    Quote Originally Posted by Jiggs View Post
    add also hidreteofit. net own by Gary Quizon. Look in their FB page.
    My Honda City 2010 retrofitted by him and still very good to date.
    last april yong everest ko naman and no issue.
    Sent from my YAL-L21 using Tapatalk
    #7668
    sirs,
    has anyone here successfully hardwired this (VIOFO A129 Duo Dual Channel Wifi Dash Camera) to our everest? thank you.
    https://www.lazada.com.ph/products/v...yHthq&search=1
    after seeing some reviews from youtube, i'm leaning towards this newer & cheaper dash camera compared to my older and more expensive Transcend. The hardwire feature is optional though but if it can be done without troubles, I was thinking why not?
    thank you sirs.
    #7669
    it could be the ac blender. its a known issue for these multi zone climate control systems.. its plastic and it cracks. you can set driver side to 18c and passenger side to 28c check if it achieves these temperatures check visavis.
    next thursday finally aayusin na nila din yun aking mouse scratching noise sa likod ng dashboard. Saklaw sya ng warranty dahil wala naman dapat tunog na emanating from anywhere kapag patay yung engine. Nag mumuangmuangan pa yung casa as if hinde common defect ito ng Everest. Balitaan ko kayo. I just followed the advise of fellow owners here na ilaban ko na ng warranty dahil eventually it will worsen.
    I had the same symptoms with my 2017 Trend, but not not consistently heard or felt. On my 40k PMS, I had it part of my complaints list, but was wary that the symptom would not be replicated during inspection.
    Good news is, using the VCM-IDS, they were able to get a DTC. They tried to clear the DTC and reflash the ACIM(?) module, but the error was still there. The fault is acknowledged by the casa.
    Bad news. The part (blender) is not available and they would still notify me when the part would be available to replace my defective unit.
    Hope this helps.
    Mar 2007
    #7670
    guys yung eve namin ayaw na bumukas ng tailgate. meron din ba sa inyo may problema like this?
    Oct 2003
    #7671
    Guys, any idea where can I get this grill?
    Jan 2017
    #7672
    Quote Originally Posted by suysuy View Post
    Nangyari din sa akin ito. Intermittent. Minsan ayaw bumukas, minsan bumubukas. Nung una akala ko mahina na ang baterya.
    Last PMS sinabi ko sa casa. Madalas daw na problema ito. Pinalitan ang liftgate motor.
    Heto ang part na nasa service order:
    EB3B404C84AC ACTU ASY LFT GT PWR 1 Piece
    Under warranty pa so walang siningil, pero tinanong ko kung magkano. 18k ang nasa doc, 36k daw kung retail.
    #7673
    finally naayos yung maingay kong actuator ng aircon 2 days bago matapos ang 3 year warranty period..Problem started when the Everest was even less than 4 months old. Ginawa nila yung Right side nung center panel nung 2 years old na...sobrang bagal ng casa kung hinde ka pa magalit.All they want to do is changed oil;change filter kahit premature pa naman and your warranty claims fall on deaf ears. Ginawa nila yung Right side nung center panel tapos nawala naman yung ingay kaso after 1 day yung Left side naman nung center panel ang may ingay.several month elapsed and naECQ pa..then I went back to casa..yung pala kapag yung left side nung center panel ang gagawin eh..baklas ang dashboard.3 days naiwan sa casa yung sasakyan. Kaya siguro hinde nila basta basta vinovolunteer na ayusin yung left side & try to get away with it kung pwede. Anyway after 3 long years, finally wala ng nagkakamot na daga sa likod ng dashboard kapag patay ang makina. #smh.
    Feb 2003
    #7674
    Buti ka pa...mine andun pa rin yung bubuwit sa loob ng dash. I have as well complained it several times while the car still under warranty kaso...lagi sabi need to observe..hayun napaso na warranty ko and nalimutan ko na ibalik...So far hindi pa rin sya tumititgil sa kaluskos sa dash till now...I think yun nagpadali sa Battery life ko, naka park kse lang car ko for 2-3weeks.
    Feb 2003
    #7675
    Si Visa Thailand ang meron nyan….OEM quality yun benta nya.
    #7676
    Lamson electronics or dunamis
    May 2007
    #7677
    Hello, ayaw na mag start ng everest namin. Tawag lang ba ako sa motolite to have the battery replaced or do i need to bring it to casa to reset something?
    Meron pala ako battery charger, safe ba gamitin sa everest yung charger?
    thanks!
    #7678
    Quote Originally Posted by eido View Post
    thanks!
    Charge mo muna battery. If ayaw then replace your battery. No need to bring it to the dealership.
    May 2007
    #7679
    haven't tried charging everest. do i need to remove the battery and charge or pwede ko charge habang connected sa kotse? normally i remove the battery and charge
    Sent using Tsikot Forums mobile app
    #7680
    No need to remove, naglow batt din sa akin after months hindi nagamit, may dashcam kasi ako nakarikta nalimotan ko unplug fuse.
    Recharge lang ako but nilagay ko sa low hindi fast charging, after 8hrs yun nag start
    Sent from my SM-A720F using Tapatalk
Ford Everest 2015
