Page 371 of 389 FirstFirst ... 271321361367368369370371372373374375381 ... LastLast
Results 7,401 to 7,420 of 7777
    Jun 2010
    #7401
    wala sir akong ginalaw, tanggal tapos lagay lang ulit yung fuse, ok na..
    Sent from my RNE-L22 using Tapatalk
    #7402
    It will get worse ... Have it replaced under warranty ... It's the aircon vent motor ... Around 1600 each plus labor which is also 1000+ ...
    Matagal ko na din na notice yung sa akin na may mouse scratching sound immediately after turning off the engine sa may glove box...anyway thank you din for pointing this out as a common defect. I ll have it checked and repaired on next visit together with the screeching brake sounds in the morning. hay!
    Jan 2016
    #7403
    While driving today, I noticed the car 'shudder' a few times while I was coasting to a stop and while idle at a traffic. Then while driving through EDSA, it was okay driving at regular edsa speed, around 40kph. When I exited to Buendia at the Paseo traffic light, the engine shut off, then I started it again and it went fine but shuddered everytime I coasted to a stop. The engine turned off a few times after it shuddered as well.
    2016 Everest with around 23k mileage. Anyone has experience this? Maybe airfilter? Alternator?
    BTW, after the engine shut off a few times, I just put it to neutral at the next stops and it was fine but everytime I'm in D and on a coast or stop, it would shudder or engine would shut off.
    Aug 2017
    #7404
    Quote Originally Posted by Eevie View Post
    Experience that before but non eve. The culprit is fuel filter.
    Sent from my iPhone X using Tapatalk
    Jan 2016
    #7405
    Quote Originally Posted by montro View Post
    Thanks. Well, it will be a test going back home later during rush hour. Hopefully it will allow me to get home.
    Jan 2008
    #7406
    madaming possible source.. pwede fuel filter, fuel itself.. check mo muna battery terminals baka maluwag lang positive or negative..
    happened to me once sa toyota altis.. nag shudder din engine when braking tapos biglang namatay.. start ulit ok naman.. pero parang may mali.. turned out na maluwag lang pala yung positive terminal
    worst case na yung may sira ecu or mechanical problems..
    Jan 2016
    #7407
    Thanks. I will check on that before bringing it in for service tomorrow morning. Driving home however this evening was uneventful, didn't experience any of the issues that happened earlier.
    Mar 2004
    #7408
    Possible fuel filter or contaminated fuel ...
    Jan 2016
    #7409
    Yes, it's confirmed - after vehicle diagnostics, fuel filter replaced.
    Jun 2008
    #7410
    nakapagkarga ka siguro ng maruming diesel at wag isasagad sa halos empty tank before mag refill. may same experience ako dati sa ibang unit.
    Jun 2011
    #7411
    Fuel filter or Crankshaft sensor
    #7412
    May malfunction kanina morning ang left signal lights ko. Mabilis ang flashing indicating a busted bulb pero ok naman siya pag hazard lights. I checked it was the front left signal that was not lighting up, left signal or hazards on. But this afternoon ok na siya. I checked umiilaw na. I pulled out the bulb holder i could not find anything wrong.
    Gremlins.
    Btw, P21Y ang bulb.
    Jan 2008
    #7413
    Gremlins.
    Btw, P21Y ang bulb.
    baka contact issue lang.. soldered lang kasi yung pwet nung bulb kaya minsan pwede mag loose contact.. try putting some silicone grease sa contacts.. small amount lang just to lubricate
    Jun 2011
    #7414
    Guys.. May Accesories shop nga pala ako... Puro Everest accessories lang ang binebenta ko... Je he he para libre upgrade...
    Sent from my BLA-L29 using Tapatalk
    Mar 2004
    #7415
    Use dielectric grease ...
    Aug 2017
    #7416
    Bro how much for complete hitch receiver w/ tow ball. (Eve 3.2 totl)
    Oct 2003
    #7417
    Btw, P21Y ang bulb.
    Maybe a good time to change to LEDs? Ito sana next project ko but ung tailight cover sa likod looks like a pain to remove though.
    #7418
    If you change to led, you need also to changes settings through forscan, otherwise it will be detected as a busted light bulb
    Sent from my SM-A720F using Tapatalk
    Oct 2003
    #7419
    Kahit may built-in resistors na ung bulb?
    Nov 2018
    #7420
    In my opinion, it is quite possible that it all depends on the engine. If the engine is good then this type of problems rarely happened.
Ford Everest 2015
