Page 367 of 389 FirstFirst ... 267317357363364365366367368369370371377 ... LastLast
Results 7,321 to 7,340 of 7777
    Aug 2018
    #7321
    Quote Originally Posted by gomez_ea2 View Post
    having a regular PMS sa dealer, air con is good like when I bought it, then replace my intake filter to knn, always using Petron turbo diesel..
    dirty radiator? bugahan lang ba ito ng pressurized water.. kumbaga yung mga fins lang nya?
    Sent from my RNE-L22 using Tapatalk
    And check your tires.
    Oct 2014
    #7322
    Air filter like what stock said.
    Change your fuel. Mababa mileage ng shell diesels. Best is caltex.
    Shell before, now seaoil. Ok ba talaga caltex sir(inulit ko lang, hehehe!)? Para makalipat na rin.
    Oct 2018
    #7323
    Someone was told by their SA that they can only use Shell diesel fuel on their 2018 Ford Everest or warranty will be voided ... and these people follow it ... Told them it's not true ... Still ...
    Whoever said that is either stock holder sa shell or just plain stupid. Nice post sir.
    Oct 2018
    #7324
    saan ka nakakuha sir and how much?
    Yes sir San nabili and what model sya pwede
    never pressurized water sa radiator, fins will bend. normal running water.. soak then rinse.. 3x
    foam gun sana if meron.
    Jun 2010
    #7326
    what is your ideal tire pressure for comfort and efficiency (275.55.20)?
    #7327
    35 psi.
    36-37 psi when fully loaded (with luggage on the roof basket).
    #7328
    32Psi - 1-2pax
    34psi - 3-5pax
    34Psi front & 36psi rear - full load
    Jun 2010
    #7329
    Quote Originally Posted by Noel Salisipan View Post
    32Psi - 1-2pax
    34psi - 3-5pax
    ramdam mo ba difference sir pag mag kaiba yung tire pressure ng front and back?
    #7330
    Yup, pag nadadaan ako sa ramble, yung guhit ng daan. Pero mas ramdam ko sa harap between 32psi vs sa 35psi na recommended.
    Sent from my LG-M400 using Tapatalk
    Jun 2010
    #7331
    kasi pag below 32psi, delikado daw sa sidewall, hays might go talaga sa 34-35, kahit matagtag
    #7332
    Na try ko na 32 psi, under inflated yan for 275/55r20 tires. Mapupudpod agad ang outer thread saka mag-feathering. I slowly increased hangang umabot sa 35 psi dun ko lang napansin na hindi na nag-progress yung uneven tire wear. Kung tinuloy-tuloy ko na 32-33 psi lang baka di pa umabot ng 30k km yung nitto g1.
    Jun 2011
    #7333
    Check mo kung umiilaw pa din yung vanity mirrors sa sun visor. Pag hindi na then fuse lang yan. The lights on the sun visor mirrors and the moon roof are tapped to the same fuse, fuse #1 in the driver's side kick panel. 10 amps micro fuse siya. Madaming fuses dun na hindi ginagamit bunutin mo muna yung isa na spare.
    Mahirap hanapin micro fuse. I've been to ace and handyman. Mukhang need pa pumunta ng banawe e ayaw ko punta dun hirap sa parking.
    It means naka open ang moonroof mo... Naka angat pa... Close mo using the keys..
    Jun 2011
    #7334
    Can you ask the sa how much this pump costs, fir the benefit if us guys whose units are already past the warranty.
    Dont worry.. I can source this out.. I can get it way cheaper than Banawe prices..
    Jun 2011
    #7335
    Guys If you want To get the lowest PMS casa price... MESSAGE me on my messenger.. I can help.. We have a partnership with All branches of Ford Autohub Group in the phils. Pati warranty claims....
    Jun 2011
    #7336
    Guys light trail sa Balagbag
    Mar 2004
    #7337
    Rumble strips ...
    Jun 2010
    #7338
    ask ko lang, ano FC nyo sa 3.2? yung may light traffic sa province like mga 40-60 kph lang ang takbo...
    Jul 2016
    #7339
    I remember yung SA ko sobrang recommend ng Shell kahit na ang binigay sakin ay discount card for Caltex. LOL. Pero wala namang na mention na warranty will be voided.
    Industry folks na mismo nagsabi na pare-pareho lang ang mga diesel quality ng available satin. And sa additives lang nagkakatalo na hindi pa din proven ang effectiveness. Basta ako, I'm utilizing Caltex. Sayang ang discount card!
    Also, I heard a couple of guys talking sa casa nung nag visit ako, na ang diesel daw mas maganda yung every 5k ang change oil and that ganito din daw ang ginagawa sa ibang countries. Since wala akong alam sa diesel maintenance, dahil first time ko mag diesel, is there any truth to this?
    #7340
    Been using mine for more than a year pero wala namang side effect, except mas type ko ang feeling while driving.
Ford Everest 2015
