Results 11 to 20 of 26
    eto ba yung same sa ecosport na parang may nakapatong pa sa ibabaw ng battery?
    If you are referring to the big box above the battery of pre-facelift EcoSport, that's the ECU (I think this was relocated beside the battery on newer models).
    I believe the EBS (Electrical/Electronic Battery Sensor) is the small boxy thing attached to the negative cable/ terminal of the battery. I googled an example of an EBS.
    Electronic battery sensor
    di ba sarap sakalin ng auto design at engineering department ng ford.. why make a simple thing like changing air filters too complicated..?
    my guess?
    it's probably cheaper to manufacture than the alternative.
    Jan 2016
    Ayan sya, taken from a post in FB, dyan napuputol ang bracket, ung hindi putol ang akinfb_img_1610090146452.jpgimg_20210109_090627.jpg
    Sent from my Mi A1 using Tsikot Forums mobile app
    Thanks for sharing.
    Nov 2019
    Naka schedule na yung replacement sa unit nyo po?
    poor design.
    with all that vibration, one would have expected... heck! in all due humility, i could have predicted that breakage!
    the old designers who used their noggins instead of the computers, have probably all retired...
    Jan 2016
    Quote Originally Posted by carxynogen View Post
    Di ko pa alam bro kung kasama ung akin sa recall
    Jan 2016
    poor design.
    Doc, if you're referring to the shape where the bracket comes down from the battery sensor towards the battery pole, you'll be surprised to know, they're replacing it with the same design. But they took out that other branch that goes the other way and grounded to the CVT.
    highs!
    it'll probably last longer, but will still fracture just the same.
    it's still the same lollipop design!
    lollipop. relatively thin, light bracket, heavy head.
    in the olden days,
    the battery terminal was connected to a long, flexible cable that did not mind vibrations...
    Nov 2019
    highs!
    in the olden days,
    Yung problem is if in the middle of road trip mag break.
    Okay sana if madaling i DIY, mag stock lang ng extra part ang owner.
[2021] Ford PH issues recall (Territory's Electric Battery Sensor bracket)
