Results 11 to 20 of 26
February 22nd, 2021 06:53 PM #11
If you are referring to the big box above the battery of pre-facelift EcoSport, that's the ECU (I think this was relocated beside the battery on newer models).
I believe the EBS (Electrical/Electronic Battery Sensor) is the small boxy thing attached to the negative cable/ terminal of the battery. I googled an example of an EBS.
Electronic battery sensorLast edited by AG4; February 22nd, 2021 at 07:03 PM.
- 54,205
February 22nd, 2021 07:58 PM #12
February 22nd, 2021 08:00 PM #13
Ayan sya, taken from a post in FB, dyan napuputol ang bracket, ung hindi putol ang akin
Sent from my Mi A1 using Tsikot Forums mobile app
- Nov 2019
- 1,407
February 22nd, 2021 09:50 PM #15
- 54,205
February 22nd, 2021 10:40 PM #17
Di ko pa alam bro kung kasama ung akin sa recall
February 22nd, 2021 10:42 PM #18
Doc, if you're referring to the shape where the bracket comes down from the battery sensor towards the battery pole, you'll be surprised to know, they're replacing it with the same design. But they took out that other branch that goes the other way and grounded to the CVT.
- 54,205
February 23rd, 2021 12:07 AM #19highs!
it'll probably last longer, but will still fracture just the same.
it's still the same lollipop design!
lollipop. relatively thin, light bracket, heavy head.
in the olden days,
the battery terminal was connected to a long, flexible cable that did not mind vibrations...
- Nov 2019
- 1,407
February 23rd, 2021 12:46 AM #20
Buti nalang hindi binintang yung kotse since hindi naman siya monterosport. It would be different...
