Results 281 to 290 of 291
November 4th, 2020 02:58 AM #281
another facelift before the 2022 model...
https://www.autoindustriya.com/auto-...-for-2021.html
- Jan 2007
- 2,234
- Jan 2008
- 4,726
- Aug 2008
- 164
April 27th, 2021 05:04 PM #285I would like to ask if timing belt or chain ang ranger and mura lang po ang maintenance like the usual change of oil & filter.
April 30th, 2021 02:17 PM #286
- Nov 2019
- 973
February 3rd, 2024 10:02 PM #287Dumaan lang sa feed ko.
Ano kaya reason why bumigay na transmission nitong Ford Ranger 2019.
Page Not Found
- 52,731
February 3rd, 2024 10:23 PM #288dunno if it's the same, but
a kakilala's everest once got stuck in the parking slot. it wouldn't shift to D or R, either.
turns out, may lumuwag or kumalas lang sa ilalim nang trans box.
the driver of the towtruck they called, crawled under and "put it back".
apparently, it was a common-enough occurence, the towtruck driver said.
i forgot the name of the part involved.
- Feb 2014
- 2,536
February 3rd, 2024 11:18 PM #289
February 3rd, 2024 11:46 PM #290
Ive read a lot of bad things about the 10 speed transmission, which only the 4x4 wildtrak and raptor uses
high idle RPM at engine start
