Results 1 to 10 of 42
- Oct 2013
- 20
January 26th, 2015 12:50 PM #1Hi Guys! I want to get your input. I'm looking to buy a 2011 Ford focus Hatch, 1.8 engine, automatic, gas with leather seating and Back sensors. it's currently at 27,000Kms and it's being sold to me at 450k negotiable. What do you think? Good buy or should I go look elsewhere?
Thanks!
January 26th, 2015 12:55 PM #2
450k... tawaran mo pa. Ang mahal nang parts nyan.
Pinto pa lang nyan hindi basta basta pwede pagawa kung saan saan.
January 26th, 2015 01:51 PM #3
The 1.8L model of the previous gen Focus is not known for fuel efficiency. You'd be better off with the 2.0L gas model or the much better Focus TDCi model. The Focus TDCi is way more fuel efficient with its 2.0L turbo diesel engine, not to mention it has better performance than the petrol-powered models. Price will be around 450k-550k nowadays.
- Feb 2014
- 18
March 22nd, 2015 03:10 PM #4Sir sa aken naman binebentahah ako nang ford 2011 2.0 tdci model. Asa 80Kms na sya actually tapos ang asking price nya is 500k.
Trusted ko naman ung owner tapos casa maintained pa. May new head unit sya na kenwood na may rear camera tapos new rims.
Good buy pa kaya sya considering 80kms na, kahit casa maintained?
- 54,205
March 22nd, 2015 03:14 PM #5
- Feb 2014
- 18
March 24th, 2015 12:39 AM #6
- Dec 2014
- 165
March 24th, 2015 01:57 AM #7Make sure it isn't flooded or trashed.
Things to check:
Worn engine mounts - tdci has 3 of these, each costs 8k to replace. Clunking sound whenever you step on the throttle is evident when needs replacing.
If it has the powershift transmission, ask if he have already changed the ATF at 60k kms. Powershift uses special ATF for dual clutch gearbox which costs 2k per liter at Ford. The car uses 5liters but you need 8liters for dialysis. Erratic shifting is apparent if ATF is left dirty/unchanged.
Timing belt is a candidate for replacement at 80k kms. Could last you until 100k kms though.
Also check when he last replaced the battery as the tdci electronics heavily depend on it.
If it has 80k kms from 2011, it means the car is always driven and enjoyed, hopefully not raced.
As long as the car is religiously maintained, doesn't smoke and gets only diesel from clean pumps, then yes it is a good buy.
- 54,205
March 24th, 2015 12:18 PM #9
Pass ka na lang stick with the japs. Its tdci and power shift if automatic.
Dont know why they stopped the selling the tdci. But that alone is scary
- Feb 2014
- 18
March 24th, 2015 11:49 PM #10thank you sa input sir.
so far di naman nabaha, tapos new battery sya. ung mga atk di ko pa sure, nung last time na nakisakay ako sa kanya, wala naman syang unusual sound.
question lang, madali kaya mga parts nya, like ung mga atk, timing belt if kailangan na nang palitan?
thanks again
A young child and a 29 year old shouldn't have lost their lives if only the driver was more careful
