Page 3 of 10 FirstFirst 1234567 ... LastLast
Results 41 to 60 of 184
    Quote Originally Posted by Jiggs View Post
    Are you saying Sir kahit nakaswitch on ang lights, normally kase once you turn off the engine cabin lights and park lights will lit up and once mo ma lock ang car it will slowly fade to Off. Kapag nakaswitch on ang lights it will stay ON.. I haven't tried it na pabayaan na naka turn ON if mamatay after a while...
    I think its called battery discharge protection. wait for 5 seconds and observe.
    Feb 2003
    #42
    Have Tested it for an hour....I've intentionally left the park light ON....There is no Battery Discharge Protection Features....at least for my unit.
    So kapag naiwan mo tlaga nakaswith ON ang lights mo it will remain lit...And just this morning sa office one of my workmate who have as well an Eve nilapitan ng guard kase naka park light and cabin lights ON sa parking. Mga 2hrs na naka ON bago sya naadvice...nagstart pa naman ang Car nya.
    Mar 2016
    #43
    IMHO, I think the battery discharge protection activates only if it is in critical status. It will auto-shut off all electrical gadgets. Meaning you can still start your car but some gadgets will not function until your car start.
    May 2016
    #44
    Normal po ba na naka sindi ang parking lights sa harap when you turn on the ignition key and even kahit pinaandar na ang makina? Even you select the "0" in the lighting control dial? I just don't know of its a standard feature or setting. Medyo hassle if you don't want any lights on if idle ka sa parking.
    Mar 2007
    #45
    Quote Originally Posted by Fritzroy View Post
    Daylight running lights yan sir standard feature na ksama ng high beam off lng sya temporary kung signal light kanor emergency light ask ko sa bgc d pa rin nila kaya ioff yang drl using their program
    May 2016
    #46
    Quote Originally Posted by bigeebabee View Post
    Sir thank you sa input. Correct me if I'm wrong sir. Yung DRL ba is yung ilaw sa upper corner ng head lamp near the grille? Trend po ang unit ko. Yung hindi ko po kasi ma off is yung malaking lens kit sa gitna tabi ng projector lights. Pag gabi o umaga lagi tuloy may bukas na ilaw sa harap kahit kinakalikot ko lang ang auto and bukas as radio.
    Mar 2007
    #47
    subukan m ion yung parklight dapat naka off yung drl/high beam isa lng bulb nun drl 15 watts high beam 55 watts consumption pag susi m sa on bkas agad yan yung maliit na bulb na mahina sa araw parklight mo yun gsto ko rin ioff yung sa kin laginako hintay pag me dumaan sa parking kala aalis na ko parati hehehe
    Jan 2011
    #48
    Sakin din when you switch the lock icon in the remote twice the cabin and park lights will turn off. Try nyo ulit sir.
    Apr 2009
    #49
    multiple reports of headlamp problems on titanium premium variants (level issues).
    Apr 2009
    #50
    Quote Originally Posted by ferrarifan View Post
    now i also belong to this club. my left headlamp is tilting downward since tonight. it was still okay when i used it last night.
    i read some have brought their units to casa and ask for replacement of headlamps. downside is it takes at least 2 months of waiting for replacement parts. is this the only viable solution to this problem?
    Apr 2009
    #51
    I brought my unit at HID Retrofit (HIDRetrofit.net - HID Projector Retrofits | LED Lightning Innovation) this afternoon and they adjusted my headlamp. They also removed the power supply to the auto leveling motor, so now my headlamps are fixed and not moving anymore. Very happy with the result so far, and it's a cheap and quick fix to this problem.
    Dec 2015
    #52
    magkano sir?
    Apr 2009
    #53
    Quote Originally Posted by jeff1990 View Post
    magkano sir?
    1K pesos boss.
    Jan 2011
    #54
    Mga sir help po. Ano po need ko remember or to take note before upgrading ng rims and tires? Currently po stock everest 2016 18" rims. Plan to upgrade ng 20" worx wheels with 275/55/20. Help po mga sir ano po need ko gawin or dapat malaman before upgrading. Thanks.
    #55
    Quote Originally Posted by Unwired View Post
    Rim & Tire Size Calculator. Custom Offsets - Wheel-Size.com
    Mar 2016
    #56
    Sirs.. Magandang hapon ho.. Ask ko lang mga sir/maam after our 1st pms (trend) yung usok nya similar sa amoy ng lpg sa mga cab. Is this normal? And ano diesel marecommend/gamit nyu? V-power or the regular diesel? Maraming salamat po
    #57
    Quote Originally Posted by fmbs21 View Post
    hehehe, hindi ko inaamoy yung usok, bad yan!
    regular euro4 diesel lang bossing. ako loyalist ng unioil pero pag walang makita pwede na din euro4 diesel ng caltex-shell-petron in that order. pag wala pa din pwede na seaoil (euro3).
    caltex almost same as unioil with the added engine cleaner (if it really works?)
    shell regular mabilis maubos. shell turbo-diesel mas mabilis maubos.
    petron says they have a new euro4 refinery daw. last month nagkarga ako ng turbo diesel nila. imho the 3-4 pesos premium ain't worth it for the minimal gains it gave.
    #58
    i'm planning to install these as back-up for the head lights in case what happened to some of you here happen while i'm on the road. also double purpose na din when i go to my farm. these are hella 500 black magic off road lamps left over from my ex pick up.
    but i don't want to install bull bars/nudge bars. my plan is to replace the grills with black honeycomb grills and install these behind the grill. stealth install kung baga. however the honeycomb grills available are only simulated, stick-on grills that only cover the existing grills. magkano kaya pa-fabricate, and where?
    or is it possible to install hella type lights on the eve without the use of a nudge bar?
    Mar 2004
    #59
    How about LED bars? Would cost about the same as fabricating a new grill. LED bars are easier to conceal too.
    #60
    yes i've considered that too. kaya lang led light being at 6000 kelvin will be useless in the rain. these are halogens. i've tested this before during heavy rain and there is minimal light reflection from the rain drops plus the light throw is quite far. also, unlike leds which have lots of glare, this has a very good cut off so i will not be blinding oncoming motorists.
2015 Ford Everest Problems / Wish List
