Biglang hindi na gumagana ang automatic roll down ng windows ko kahit pa ipush ko sya all the way naging manual na lng. May nakaranas na ba nito? Tiningnan ko ang fuse box pero ok naman mga fuse ng windows. Baka lng may nakakaalam ng diy repair nito sir.
sa akin naman, nung nai-set ko sa autolock yung door, di ko na maibalik yung feature na pede pa rin i-rolldown or up window after turning of the engine, which was the default setting when I acquired my T6. Convenient din kasi yung ganung feature especially when you're waiting for someone and needs to turn off the engine, what happened now is I need to set the key position to ON before I can rollup or down the windows.
I was following a 3.2 wildtrak at nlex this morning, nadismaya ako kasi wala pa siya plate number and it was smoking. Speed was only 110 kph. Hindi naman black/dark smoke (not like a montero anyway), just enough to be noticed. Has anyone of you experienced this already? I'm asking kasi if i buy another vehicle next year i'm planning to get either a new ranger or if the new everest comes out (same engine if the rumors are true).
nangyari sa akin yan nung dinisconnect ko ang battery, nasa manual ang instruction paano mareset to auto uli..switch ignition to on then roll up ang driver side window and hold for 3 sec. until you hear a click sound ng relay, then ok na.
Mga bossing, anyone encoutered headlight moisture? Sa akin sa edge ng driver side headlight nag moist kapag naka on ang headlight at uminit na sya. Mawawala din naman kapag naka off na ang headlight at hindi na mainit.
Had that problem on my 2.2 MT Wildtrak a couple of weeks ago...i was traveling on the highway going home...sabay pa sila umilaw ng ESP. napansin ko lang parang humina yung power...kaya i lowered my speed. Kinabukasan umilaw uli. Then after that di na bumalik. Today ko pa lang sya mapapasok sa casa for check up.
By the way, I scanned it using my mini OBD2 scanner. Ang lumabas na Fault is P2565 : Turbocharger Boost Control Position Sensor Circuit High. Di ko alam ano yun... :-D
Sent from my HTC Butterfly using Tapatalk
