Results 1 to 10 of 22
- Sep 2005
- 59
June 5th, 2007 11:04 AM #1Mga Sir what could be possible cause ng white smoke during idle only and sometimes pag reverse ko?Car is 7g Galant.I add only 1 liter of oil every 5 mos para lang ma top up. Is that bad already? Pati sunog ng sparkplugs ok and early morning startups nagtutubig pa. Di ko alam whats the cause. Do I need a compression test to determine if my seals needs to be replaced or piston rings maybe? TIA
June 5th, 2007 01:44 PM #2
AFAIK.
Unless there is no oil loss, you need not to add engine oil or else excess oil will create too much pressure that it gets past your piston rings and it may be one of the reason why white smoke comes out.
Too much oil may also cause too much heat and will eventually damage you piston ring and even the block.
Damaged piston rings will cause white smoke and some power loss.
June 5th, 2007 05:51 PM #3
Nagto2p-off ka ng engine oil every 5 months para lang mamaintain ang oil level mo chief?
Posibleng nagsu2nog na ng langis yan bro.
Better na ipacheck mo na po, baka kailangan na ng top-overhaul.
Check mo din ang radiator mo, if lagi kang kulang sa coolant or water then nagsu2nog ka na ng coolant. Posibleng kailangan mo ng magreplace ng head gasket cheif.
Have it checked as soon as possible.
hth.
- May 2007
- 60
June 6th, 2007 05:25 AM #4nakikita mo ba kung meron ding white smoke sa exhaust kapag nakahinto ka at umarangkada?
June 6th, 2007 05:36 AM #5
Early morning condensation is normal. If you suspect engine is bad, see if you're losing coolant and oil at the same time, or if one or both are mixing.
- Sep 2005
- 59
June 7th, 2007 12:06 PM #6Mga Ser thanks sa mga replies nyo. As for the coolant normal lang po. Di nababawasan ang reservoir and no over heating naman. Yung smoke pansin ko lang sa traffic pag titignan ko sa side mirron meron pero konti lang naman. Pag hataw ko wala po smoke.Gamit ko oil pala is Motul Htec 10w-40. Iniisp ko baka manipis kaya nababawasan. Thanks sa mga inputs nyo bros. Observe ko pa rin siya..
June 7th, 2007 12:42 PM #7
Kung nababasa ang spark plug mo may problema sa head gasket, at sa sinasabi mong puting usok yan ay tubig na nasusunog dahil sa leak na nakakapasok sa combustion chamber mo. Kukunti pa lang ngayon pero sign na yan na busted na ang head gasket mo. Spend now before the worst.
June 7th, 2007 01:00 PM #8
burning oil is bluish.
burning water/coolant is white (correct me if im wrong)
happenned to my 7g Vr V6.
Zombie
- Aug 2006
- 728
June 7th, 2007 03:08 PM #9
June 7th, 2007 04:23 PM #10
[SIZE=3]Mga bros paano naman po kung yung white smoke lumalabas sa may breather sa head cover gasket tuwing nire rev ang makina? Hindi naman sa tambutso lumalabas. A friend has been asking me this question at timing nakita ko itong yung thread. [/SIZE]
[SIZE=3][/SIZE]
[SIZE=3]Hindi naman po nagbabawas ng oil at okey naman ang takbo. Basa nga lang ng oil yung thread nung spark plug. Kailangan na po bang i overhaul or papalitan din lang yung head gasket at O-ring? TIA. [/SIZE]
Discover the ultimate in relaxed romance with the best casual dating platform! Authentic Ladies ...
Exemplary Сasual Dating - Verified Damsels
