Results 11 to 12 of 12
- Nov 2006
- 201
October 6th, 2010 11:33 AM #11sorry sir, i have no idea on prices. but im almost certain (95%) that culprit is the un-retightened cylinder bolt heads. im sorry to say but you have to replace again your gasket and this time "never" put gasket maker (shellac, etc). the orig gasket is more than enough.it's useless flushing your radiator if you dont replace your warped gasket.before you knew it, it's actually easy to disassemble the head but putting it back really needs a torque wrench...good luck!
October 7th, 2010 10:52 AM #12
Additional test done this morning. Started the engine cold with radiator cap on. Pressure builds up in the cooling system with the engine NOT WARMED UP YET (after approx 1 minute). yet still no contamination in all fluids.
Hayyyy!!!! it must be the HG again.....
Any idea folks if the head bolts on a 4d56 torque-to-yield or not (i.e. reusable)?
Last year was my first time to change gaskets, so i might have affected the plastic deformation of the bolts since i did not replace them.
I torqued the bolts to specs then 90 deg + 90 deg. is this right tightening sequence?
Xiaomi E-Car
