Results 21 to 40 of 49
    Aug 2017
    #21
    Quote Originally Posted by sirkosero View Post
    On my vios, whenever i feel lile it. Minsan i clean every month. Minsan every 6 months. Minsan, every saturday morning. Super dali lang naman
    I do it when im bored.
    Sent from my MI MAX 2 using Tapatalk
    I've plenty of TBs to clean, are you bored now?
    Aug 2017
    #23
    MUkhang effective yan ah.
    It's a bit pricey pero mukhang ok.
    Btw, any tips to clean the maf sensor?
    1) Don't stare hard on the MAF... it might break
    2) Use a CRC MAF cleaner, don't be cheap... The MAF sensor is expensive
    3) 10-15 1sec bursts per CRC instruction
    Pretty straight forward lang MAF cleaning ... Dami sa Youtube
    Apr 2012
    #24
    Quote Originally Posted by SidCoronel View Post
    DIY... If you wanna clean your entire intake system try Revive...
    okay, thanks. looks easy and convenient[emoji108]
    #25
    Actually merong tutorial galing Indonesia at parang madali ding gawin at sa gasoline station yung 1.2k. Dun sa ka-club namin wala ng reprogram, may mas mura kay dadudz at that price kasama na sa PMS niya change oil and brake cleaning, toyota expert pero pwede rin siya ibang brand.
    Sent from my ASUS_Z017DA using Tapatalk
    Correct ka dyan... Start and idle your engine for 2mins with all other accessories off... Turn on all accessories on (especially a/c)... Idle for 2mins... Apply hand brake + step on brake pedal... Place on D... Idle for 2mins... Your good to go
    baka gusto lang nya justify yun cost ng service nya.
    sinama ko rin air intake baklasin.
    not bad for 70k km odo
    yun sa vios noon, at 180k km iirc kulangot na nadudukot ko hahaha
    btw di ko na nakunan pics yung after, andungis na ng kamay ko eh, napunit nitrile gloves hehehe
    Apr 2012
    #26
    madali lang yung maf sensor bro, unscrew lang then spray ng maf cleaner. contact cleaner nagamit ko ok din. i even used cotton buds with IPA dati, ok din naman, wala naman masyado dumi kaya kahit spray lang ng cleaner. careful lang dun sa sensor probe na hindi magalaw o madamage.
    its the throttle body and the intake manifold that i am tempted to clean but hindi kaya ng "baklas-kalikot skills" ko kahit may tools ako[emoji2960][emoji16] may mga sensors na nakakabit mahirap na. egr kaya ko, ako naglilinis dati. wala na gunk since naka blanking kaya di ko na binubuksan[emoji846]
    #27
    naisip ko rin maglagay dati ng oil catch can. kaso every 20k km naman ako plano maglinis, tapos itong ginawa ko kanina 70k km, di pa ganun kahirap linisin. baka ok lang every 50k km.
    Apr 2012
    #28
    naka occ pa din yung unit ko pero lately very minimal o wala na naiipon na oil. di ko na nga matandaan last ko nai-drain since wala naman laman. i checked yung outlet hose ng occ at very faint lang yung traces ng oil. so i assumed na yung blow by gas is more in vapor form and less na yung oil.
    #29
    tama ba, ok engine condish bro pag wala or minimal sumasama oil sa blowby?
    #30
    You're right bro ninja, parang madali lang linisin ang TB
    Tutorial Bongkar Throttle Body Suzuki Ertiga - YouTube
    Bersihkan throttle body suzuki ertiga - YouTube
    On the MAF just spray contact cleaner and may nabasa ako na huwag hawakan dahil nga sensitive ito.
    #31
    Nakalinis na ako dati ng throttle body ng civic ek ko dati & medyo matrabaho kasi may gunk na din hehe
    Looks like straightforward nga ang paglinis ng maf sensor. Tamang tama may contact cleaner pa ako sa bahay. Need to be extra careful din pala handling the sensor.
    Naka blank din truck ko sa baka no need to clean its throttle body for now.
    Apr 2012
    #32
    i believed ganun nga bro...
    may mga nakausling sensors sa throttle body kaya hesitant ako galawin[emoji16] ipatrabaho ko na lang sa mekaniko if i decide to have it clean para sabay na rin yung intake manifold. may naglinis na dati na kasama sa club, i think posted din dito. maraming bolts na tatanggalin, matrabaho. the spray cleaner posted earlier might to the trick as it passes the turbo, intercooler, tb all the way to the intake. medyo costly nga lang. parang ini-spray mo yung 5.5k petot sa air intake then ilalabas na usok sa tambutso[emoji2960] nothing beats the old school way of baklas-linis-kabit but if it can dissolve the gunk and clean the internals the easy way then why not[emoji2369]
    #33
    mga bros alam nyo kung ano panlinis ng vvt sensor?
    gasoline din ba?
    Mar 2019
    #34
    When nag ro rough idl. then pag may free time wag lang excessive
    Feb 2019
    #35
    how about the intake manifold, have you tried cleaning it too?
    Feb 2019
    #36
    Sent from my SM-G960F using Tapatalk Tutuapp 9Apps ShowBox
    #37
    Quote Originally Posted by lala31 View Post
    Intake Manifold Cleaning And Removing Carbon - YouTube
    #38
    ...it still looks dirty to me...
    has anyone tried a metal brush instead? ...one of those rotary things...?
    #39
    ill try it on my 80k km bro (currnetly on 70k km), sana malala ko i-post dito hehehe
    Apr 2008
When should the MAF sensor be cleaned?
