Page 1 of 3 123 LastLast
Results 1 to 20 of 51
    Jun 2013
    3 sasakyan gamit ko: Mitsubishi Montero Sports GLX M/T 2010 , Honda City Lxi 1999, Toyota Hilux 2.4 1994......every 5000 kms. ako magpalit ng langis at oil filter kada sasakyan. ok lang ba to?????? kaso, umaabot ng 6mos. to almost 1 year bago ako maka 5000 kms bawat sasakyan.... retired ba kasi ako...... maganda pa kondisyon ng langis na pinagpalitan ko.....di pa gaanong maitim at di lumalapot langis.....ok pa naman andar ng mga sasakyan.....wala pang ino-overhaul at di mausok......puro malakas pang humila.....maski yung 1994 Hilux ko...... Ano po masasabi/maipapayo niyo?????? Salamat!!!!!!
    the recommended change oil interval is 3 months or 5000 kms whatever goes first, but I've read that somehow, this rule may not hold true. but then, oil changes are cheaper than to have a damaged engine.
    ako, i get my 5000 kms in around 4 months... dun na lang ako nagpapalit.
    Oct 2011
    Quote Originally Posted by kajjo1 View Post
    ano ba langis ginamit mo mineral or fully synthetic oil???????
    Jun 2013
    Retz, Top 1 synthetic oil (diesel) sa Montero.....Shell R3 sa Toyota Hilux at Shell Helix J sa Honda City
    Oct 2011
    Sir ung Top1 hindi un talaga FS oil. Kaya every 5K-7K change oil. The rest every 3K-5K OCI.
    Jan 2004
    I usually go with what the user manual states. It also provides additional guidelines if the car is driven hard, or driven in a lot of traffic, or pulling heavy loads. Usually more often. One of mine says every 5k mi. or 6 mos. for mineral oil, 10k mi. or 12 mos. for synthetic, the other is 5k mi or 12 mos. mineral only, 15w40.
    May 2012
    Change oil only when they are dirty and sticky, there is no hard rule in changing oil. Remember that oil only prevent the friction of engine metals and so they gather dust and some engine residue that is why you change them. I myself have been using cars of different brands for almost 20 years and sometimes I change oil a year or a year and a half only when it is dirty & sticky. Your engine has a filter to keep it clean and the dirt that accumulates that cannot be filtered are the ones that mix with the oil. Changing oil every 5000 km was the marketing strategy of oil companies to keep them selling and they just heat or scrub the oil to purify it and then sell it to us again.....
    if i can heat and scrub the oil to purify it at reasonable cost and effort so i can re-use it, i'd do it, too.
    Feb 2003
    I tend to agree....but the irony of it even the oil company doesn't really adhere to that frequent oil change...my Take on this is these we're all overly blown out by this marketing people..siemfpre Sales comes first. They even came up with some high falluting terminologies just to sell their oils. I have worked to diff. Oil company na and all of them follow the oil test results and not the 6 months/yearly change of lubricants. Their internal combustion engines sometimes reach 3 years before an oil change...siemfpre Merton sila ng routine oil sampling and from there they based their maintenance strategy. And that's using mineral oil.
    Sep 2008
    baka car manufacturer not the oil compnay.
    daily drivers every 3- 6 mos. pag garage queen once a year
    Oct 2011
    meron din mga cheap alternative na FS oil. since na mura lang, change oil sila every 5k even with FS oil.
    IMO, changing once a year/every 5,000kms is fine. In that case i'd probably use synthetic oil.
    Jan 2009
    Motor oil does four fundamental things:
    1. Lubrication - This is self-explanatory.
    2. Soot Detergent - Soot will always be produced by the engine as a by-product of internal combustion so it is important that the oil continually be able to do its job of removing it. By design, engine oil is blended with additives and detergents to help remove soot build-up that would otherwise cling to parts and oil passageways.
    3. Soot Suspension - Removing dirt and soot is one thing. The motor oil must also carry the displaced dirt to the oil filter to trap them.
    4. Coolant - Yes, motor oil complements the primary cooling system of your engine. The primary cooling system typically just cools the cylinder walls and head. The engine oil cools the other important parts where coolant water wouldn't and shouldn't be. For example, most cars nowadays would have oil jets underneath the pistons to help cool them. This is besides the fact that the lubrication properties itself prevents friction and heat build-up or at least, the oil flow helps dissipate heat build-up.
    All four properties are interconnected and a failure in one property can cause a domino effect. For instance, the detergent properties of motor oil will eventually deteriorate and get used up in time. When that happens, soot can start to accumulate, and if it becomes very bad, it can start blocking off passageways and tiny orifices. Afterwhich, the suspension capabilities of the oil is compromised and lubrication and cooling to certain parts of the engine can get affected.
    So, waiting for the oil to get sticky before replacing them is already probably too late. Manufacturers are building ever more sophisticated engines that have very tight tolerances between moving parts. Not to mention that motor oil is also used in variable-valve technology like VVT-i, VTEC, etc. to control the cam positions and such. Consider that oil passages in these systems are measured in millimeters.
    To put things into perspective, here's an example of how small an oil passageway can be... the oil control orifice on a Honda engine.
    So as you can see, using old, overdue, and sticky oil will not be ideal and may in fact cause serious engine problems in the long run.
    Oct 2011
    thanks for the heads-up bro. nice read
    Dec 2009
    follow manufacturer recommendation if your vehicles are still under warranty, otherwise follow your instinct old-timer
    you can also do a mathematical approach by keeping tabs on the amount of fuel your car needs to burn in order to cover a specific distance. as time pass by your engine oil deteriorates as it accumulates soot & that technically result in a surge in fuel consumption. so youre now faced with the dilemma of whether its more cost efficient to replace your dirty oil & save on gas consumption or keep the sullied oil & spend more on fuel. i believe this is the strategy employed by big transport company with a fleet of vehicles to maintain to save money
    just bear in mind when you opt to change oil you hit 2 birds with one stone. you protect the engine from the adverse effect of wear & tear at the same time you save on gas
    Jun 2013
    Thanks, Retz
    Jun 2013
    right ob the nose, kisshmet!!!!! thanks.....
    Jun 2013
    appreciate the inputs.....thanks!!!!!!
    Oct 2011
    no worries sir. and remember that frequent short trips a day less than 10km considered as harsh driving condition din un..... kaya mas early ang OCI.
When to change oil
