Results 21 to 30 of 51
June 13th, 2013 04:32 PM #21
5,000 km is reasonable. As to the 3-4 months interval, this depends on a lot of factors -daily driven in heavy traffic, pulling and carrying heavy loads, etc.
However, there is a cheaper way to unequivocally determine when change is imminent---look at the physically condition of the engine oil. How many of us regularly open our hood to find out?
June 13th, 2013 04:35 PM #22
Sir, i regularly check the condition of the oil (once a week) via the dipstick.
September 1st, 2013 07:47 PM #23
With due respect, buhayin ko lang ang thread na ito...
I use Top 1 HP, synthetic blend motor oil 20w50 for my 2nd Gen 4AFE, over 5 months na siya pero a little over 4k kms pa lang mileage. Nag-experiment ako sa mga low priced oil filters starting with Toyota OEM C110 which I used for 4 months, then, AGL auto filter cross ng OEM for a week, next is ViC C110 for two weeks and at present, slightly bigger diameter and longer Bosch OT 043 (cross ng OEM Toyota C113). Sa ngayon, maganda ang viscosity at light brown na ang color ng oil, smooth ang feel between fingers until now. Does this means, pwede pa use until 5k kms or paabutin ko 6 months?
- Apr 2009
- 429
September 1st, 2013 07:57 PM #24Most car enthusiast will tell you that "your eng oil is as good as your oil filter". This is very true. So invest in a good quality oil filter & buy a reputable eng oil brand acc to your budget with a viscosity that is recommended in your owner's manual. I'm more comfortable with oils that turn dark after a few thousand km mileage than the ones that remain transparently clear. The reason is very obvious...
September 1st, 2013 09:53 PM #25
September 1st, 2013 10:32 PM #26
I'm considering changing oil and filter exactly on the sixth month, that's in three weeks from today, already bought 4 liters of Caltex DGU and B131 Baldwin oil filter, will test it for 8k OCI.
September 8th, 2013 10:28 AM #29
Had just done the CO&F of my Corolla GLi at 125,667 kms. Saw the big difference in color and viscosity as when I'm checking it via dipstick, much darker at malapot talaga. Used Baldwin B131 and 3.5 lts of Caltex DGU, a little over when checked sa dipstick after a 5 minute engine run. Hope to make a 9k km OCI with this combination, that's approximately in 9 months . . .
September 8th, 2013 10:32 AM #30
pwede naman mas matagal na OCI pag gasoling powered engine compared to diesel engine.
Traffic!
