Results 1 to 10 of 21
Threaded View
January 28th, 2012 01:45 PM #8
We left off discussing that a 0W-30 grade oil is not thinner than a 10W-30 oil. They both have the same thickness at operating temperature. The 0W-30 simply does not get as thick on cooling as the 10W-30. Both are still way to thick to lubricate an engine at startup.
I have heard several people say that Porsche specifically prohibits a 0W-XX engine oil, that it is too thin. Now here is the partial truth I spoke of earlier. We will discuss multi-grade oils. Earlier we said that a straight 30 grade oil has a thickness of 10 at the normal operating temperature of your engine. The multi-grade oils 0W-30 and 10W-30 also have a thickness of 10 at 212°F.
The difference is at 75°F, your startup temperature in the morning.
Oil Type Thickness at 75° F Thickness at 212° F
Straight 30 250 10
10W-30 100 10
0W-30 40 10
Straight 10 30 6
Remember, the only difference between a 0W-40 and a 10W-40 is that the 0W-40 thickens less after you turn off your engine. It is still too thick in the morning at startup but not as thick as the 10W-40. Yet, they are still too thick to use until they both warm up to operating temperature at which point they have the save viscosity, around 13 to 14. Remember that the 0W-30, 10W-30 and straight 30 grade oils all have a viscosity of around 10 at normal engine operating temperatures. They all thicken when you turn off your engine. The 10W-30 will thicken the most.
source: bob is the oil guy forums...
http://www.bobistheoilguy.com/motor-oil-101/
If you don't have a spare tire, a tire inflator using the socket of the car as power outlet is the...
Liquid tire sealant
