pennzoil, is that ok??
Synthetic
Semi Synthetic
Regular
others
dont know
niwde11
Used oil analysis is done to gather data on metal wear in your engine and used oil quality. For example, if you sent an oil with 5000kms use, the test will determine if viscosity, total base number, flash point is within spec. Can also test for the presence of fuel and water in the oil.
Based on the results, you can determine if the oil is still good enough to protect the engine or should be replaced. This is the safest way to determine whether an oil can indeed work til 5k kms or 10k kms or more.
mobil1 fully synthetic oil
galing sa casa ng toyota bal.
ang cocorny ng mga tao dun, gusto nila sa kanila bibili. or else void ang warranty!
*** talaga... di na lang sabihin, para mas malaki ang kikitain nila sakin!...
Since I regularly change my oil at 5000 km, I use the 20w50 grade oil of seaoil and for my diesel, the 15w40 oil of seaoil, so far ok ang takbo
pepengtom
Ask toyota bal to put that condition down in writing- that unless you buy the mobil 1 from them, they will void the warranty- then send it to toyota phil asking them if this is a valid condition on warranties.
Royal Purple 14W40 for our Mazda3 and FXT. Just had the oil changed in both cars last Saturday.
Normal Engine oil pa rin po yata coz always casa lang po and isa pa Im not around that time lagi si wifey lang. This coming 20K PMS,ill change to synthetic one.![]()
4,500 pa lang engine ko kaya regular lang at saka recommended din naman ito ng toyota pasong tamo nang bagong labas ng ride ko.d4d![]()
Sa Honda City SX8 namin e Honda Mineral Oil 10-30. Mas smooth cya compare sa ibang brand na mineral oil 20-40W * mura pa, P165.00/1liter.
no need to flush na... i also doubt you will go back to mineral once you see how the engine runs on synthetic![]()
now: Castrol Magnatec
before: Mitsu mineral
langya, tumahimik makina ko nung nagpalit ako to Castrol. mas gumanda pa takbo.![]()
ehem. except perhaps for the price![]()
though the RPs come at a premium over mineral oils, they're still quite affordable. so speedyfix might actually be right, even for the price ;)
as for me using:
for Gas: Valvoline 5w-30
for Diesel: Petron Rev-X 15w-40
on next oil change, roughly another 1,700 kms to go, i'll try RP.
