View Poll Results: What type of engine oil do you use?
Voters
89. You may not vote on this poll
  • Synthetic
    32 35.96%
  • Semi Synthetic
    14 15.73%
  • Regular
    41 46.07%
  • others
    1 1.12%
  • dont know
    1 1.12%
Page 4 of 6 FirstFirst 123456 LastLast
Results 61 to 80 of 107
    Aug 2004
    #61
    pennzoil, is that ok??
    Dec 2002
    #62
    niwde11
    Used oil analysis is done to gather data on metal wear in your engine and used oil quality. For example, if you sent an oil with 5000kms use, the test will determine if viscosity, total base number, flash point is within spec. Can also test for the presence of fuel and water in the oil.
    Based on the results, you can determine if the oil is still good enough to protect the engine or should be replaced. This is the safest way to determine whether an oil can indeed work til 5k kms or 10k kms or more.
    #63
    mobil1 fully synthetic oil
    galing sa casa ng toyota bal.
    ang cocorny ng mga tao dun, gusto nila sa kanila bibili. or else void ang warranty!
    *** talaga... di na lang sabihin, para mas malaki ang kikitain nila sakin!...
    Aug 2004
    #64
    Since I regularly change my oil at 5000 km, I use the 20w50 grade oil of seaoil and for my diesel, the 15w40 oil of seaoil, so far ok ang takbo
    Dec 2002
    #65
    pepengtom
    Ask toyota bal to put that condition down in writing- that unless you buy the mobil 1 from them, they will void the warranty- then send it to toyota phil asking them if this is a valid condition on warranties.
    Sep 2005
    #66
    Royal Purple 14W40 for our Mazda3 and FXT. Just had the oil changed in both cars last Saturday.
    Aug 2005
    #67
    Normal Engine oil pa rin po yata coz always casa lang po and isa pa Im not around that time lagi si wifey lang. This coming 20K PMS,ill change to synthetic one.
    Aug 2005
    #68
    Quote Originally Posted by monsrick View Post
    When shifting from mineral oil to synthetic oil, do we need to do an engine flush?
    From synthetic oil, can we revert back to mineral oil?
    Oct 2007
    #69
    4,500 pa lang engine ko kaya regular lang at saka recommended din naman ito ng toyota pasong tamo nang bagong labas ng ride ko.d4d
    May 2005
    #70
    Sa Honda City SX8 namin e Honda Mineral Oil 10-30. Mas smooth cya compare sa ibang brand na mineral oil 20-40W * mura pa, P165.00/1liter.
    Nov 2003
    #71
    no need to flush na... i also doubt you will go back to mineral once you see how the engine runs on synthetic
    ^^^ditto on migs....
    royal purple 10W-40 user here
    Feb 2006
    #73
    now: Castrol Magnatec
    before: Mitsu mineral
    langya, tumahimik makina ko nung nagpalit ako to Castrol. mas gumanda pa takbo.
    Aug 2005
    #74
    Quote Originally Posted by speedyfix View Post
    Thanks. Gusto ko sana ang Royal Purple kaso forced pa ako na sa casa magpa change oil.
    #75
    castrol gtx every four months.
    #76
    royal purple 10w-30
    #77
    ehem. except perhaps for the price
    though the RPs come at a premium over mineral oils, they're still quite affordable. so speedyfix might actually be right, even for the price ;)
    as for me using:
    for Gas: Valvoline 5w-30
    for Diesel: Petron Rev-X 15w-40
    on next oil change, roughly another 1,700 kms to go, i'll try RP.
    #78
    valvoline synpower 5w40
    Sep 2005
    #79
    Toyota Regular Oil
    #80
    Synthetic for our gasoline and diesel engines...
    4606:rock:
