Results 1 to 6 of 6
November 26th, 2006 01:24 PM #1
Guys, I would like to ask your help. Can you recommend to me what kind/ brand of oil, oil filter and spark plug should I use for my 97 Civic Vti A/T.
I normally bring it to car shops for change oil and other maintenance and I noticed that the prices of these products are a bit jacked up. I am planning for my next oil change to just buy these items from car stores ang just pay for the labor of the mechanic. I think it is a bit cheaper.
Oil may not necessarily be fully synthetic. If you can provide the prices so much the better. Also i would appreciate if you can recommend stores or malls where these items are cheaper from other sources. thanks a lot for the usual help.
ride safe guys
November 26th, 2006 06:30 PM #2
engine oil: try motul h100. its around 380/liter
oil filter: OEM
sparkplugs:OEM NGK or Denso Iridium
November 26th, 2006 07:03 PM #3
Engine oil: Kung tamang budget lang:
Mineral oil (all 20w-50):
-Shell Helix Super (yellow bottle, P620-P650/gallon)
-Caltex Havoline Formula (red cap, P580-P620/gallon)
-Mobil1 Super XHP (P650-680/gallon) <= rare, kung may mahahanapan ka!
-Castrol GTX (P620-P650/gallon)
-Total Quartz 5000 SM (P600-P630/gallon)
Semi-syn:
-Helix Plus (10w-40, P1k+/gallon)
-Castrol Magnatec (10w-40, P960-P1k+/gallon) <= naglabasan na po sa mga auto supply 'to
-Total Quartz 7000 (15w-50, P960-P1k+/gallon) <= I'm using this one!
-Mobil Super S (15w-40, P1.2k?+/gallon) <= rare, hirap maghanap nga lang, just giving you reference!
Fully-Syn??? Kahit di na siguro kung tight budget ka lang naman, OKS na kahit semi-syn!
Oil filter: BEST if OEM parin, medyo pricey nga lang! You could also try the well-known 'VIC' Oil Filters (P140+?) (Warning: Make sure you find the authentic one...dameng fakes naglabasan nito!)
Sparkplugs: stock NGK (P90-P100/plug), or Bosch Platinum (P130-P140/plug)
NOTE: *All you can purchase/canvass at your suking auto supply, gas stations or malls near you! :D
*Above price mentioned are updated. Yes nagmahalan na po lahat!Last edited by OTEP; November 27th, 2006 at 09:46 AM.
Tsikot Member Rank 5
- Nov 2003
- 3,849
high idle RPM at engine start
