Results 21 to 25 of 25
March 18th, 2006 01:40 PM #21Originally Posted by fast69
March 18th, 2006 10:23 PM #22
Thank you guys,so do i need to drain the tank to removed the unleaded gas or i'll just add it (95+octane)
March 20th, 2006 12:28 AM #24
Drive the car till the fuel level is just at or below the empty line, then just fill her to the top to dilute the 93 Octane still remaining. Be careful, though, as you don't really know how far below the "empty" line your reserve goes.
Actually, now is a good time to find out... fill the tank to the brim when the indicator is exactly at empty, then subtract however much the gas boy put in from the manufacturer's claimed tank size. Usually, there are about 5-10 liters below the empty line.
As a reminder, for economy engines, high octane does not provide more power except if the engine is retarding timing for lower octane. But an occassional tank of high octane will help keep your injectors and valves in good condition.
high idle RPM at engine start
