Page 5 of 6 FirstFirst 123456 LastLast
Results 81 to 100 of 152
    gjtech,
    If you regularly change your engine's oil, there's no need to use engine flush. 8)
    Otherwise, a good oil flushing is recommended (not the ones containing petroleum distillates). For engine flushing, I usually use either ATF or Caltex Power flushing oil :lol: They surely make my engine internals squeaky clean :mrgreen:
    Jul 2019
    Shell.....
    petron. mineral.
    yun kasi ang meron sa hecho derecho oil change promo ng petron.
    i change oil every 5000 km.
    Hello mga tsikoteers!
    Asking po recommendations ninyo para sa suitable na engine oil for 2009 jazz gd 1.5vtec cvt? 126t kms. na.
    sa cvt di na ako makikipag sapalaran at honda branded cvt na. yun engine oil nahihilo ako sa choices 5w30 5w40? I'm tempted sa lazada ravenol semi-syn 10w40 with oil filter na for 1300pesos. Is this good enough? TIA
    factory specifications.
    you can't go wrong with 'em.
    does manufacturer say one should use synthetic or other..?
    "why spend more..?"
    10w40 semi-synthetic will be a bit thick for the L15 engine. I suggest using 5w30 viscosity. You can buy a gallon of Xteer FS 5w30 at Lazada for around 1200. You can also use Zic or Mag1.
    If you want to use regular mineral oil, just go to a Honda casa and buy their base 10w30 mineral oil. I think it is priced below 200 per liter. Honda used to offer a budget 1k change oil service using that oil. That's good for around 5k km.
    Oct 2003
    Ako gamit ko sa city gd ko is zic x7 10w-40 fully synthetic. Kakabili ko lang for 1070php/4 liters. Paired it with baldwin filter.
    I change oil every quarter since heavily used ung car.
    Mobil delvac 5w-40 acea c3 for my 2015 and 2018 kia 2.2 r-evgt engine.
    Aug 2014
    Mag1. Ultimo lahat ng Fluid mag1. [emoji846]
    Sent from my SM-G965U using Tapatalk
    Jan 2013
    Tried KIXX Fully Synth (daw) 5w30 in my Celerio. So far smooth naman.
    Feb 2015
    May nakagamit na ba nito sa inyo?
    Mobil Delvac MX City Logistics 10w30, CI-4
    Mobil Delvac™ MX City Logistics1W-3
    I'm choosing between this and Mobil Delvac MX 15w40.
    Quote Originally Posted by makelovenotwar View Post
    10w30 na.. ci-4 is good enough for most diesel applications..
    Mar 2018
    One afternoon, tumambay ako sa motorcycle supply shop ni uncle. This is in the province by the way. Napansin ko lang na sa mga naka "4 stroke" motorcycles ngayon, bestseller ang caltex havoline 20w-50 motor oil na pang kotse. Then I asked one of them kung bakit hindi niya bilhin ang recommended motor oil para sa kanyang motorsiklo, ang reply niya ay "sanay na ang motor ko sa havoline (20w-50)". Then he left.
    Tanong ko lang since I don't do motorcycles, will it be harmful to use a motor oil designed for petrol engines, onto a 4 stroke motorcycle engine?
    Anu ba ang pinagkaiba sa additives ng isang motor oil na designed para sa "4 stroke" motorcycle engines compared sa additives ng isang motor oil para sa petrol or gasoline engines?
    TIA
    Meron ba dito by the pail kung bumili ng langis? nababawasan ba efficacy nya kapag tambay siya in between oil changes?
    Anybody here heard of IPOL engine oils? The new shop I had my cars serviced offered me IPOL 5w30 FS oil, API SN/ILSAC GF5.
    after goog, its a mumbai company thats expanding.
    some indian brands:
    ipol
    servo
    veedol
    Jul 2019
    amsoil. Fully synthetic oil.
    as long as its sealed tight after opening, there shouldnt be a problem. its not like brake fluid.
    Aisin 5w30 sn/cf synthetic oil is 1.4k a gallon in binondo, semi-synth is 1.1k
    Sent from my ASUS_Z017DA using Tapatalk
    currently using zic 5w30 on 3.2monty. pino. also have petron all terrain 5w40 in stock. mura ko lang nakuha at 350/L[emoji4]. pwede na CJ pa.
What brand of engine oil do you use?
