Results 11 to 16 of 16
- Jun 2008
- 1,741
February 24th, 2011 08:15 PM #11sa tingin ko yan ay improvised blanking plate. Kaya may nakausli kasi yan ang hawakan para isingit between joint.
Kung egr yan malinaw na nakadisable na ang function ng valve. Short cut remedy baka tamad maglinis ang may-ari kaya mausok ang makina.
- Apr 2008
- 167
February 24th, 2011 09:05 PM #12
- Jul 2003
- 573
February 24th, 2011 10:07 PM #13if there is actually a slot to insert and move that thing, maybe the original sheet could have been lost or removed intentionally.
- Jun 2008
- 1,741
February 24th, 2011 11:15 PM #14Oh sorry. I don't know that that picture is from your car. Akala ko sa iba yan. Kung egr nga yan ok lang wala naman pasama mangyayari sa makina. Hindi lang gugustuhin ng mga environmentalist kasi ang egr is to minimize NOx emission ng sasakyan.
February 25th, 2011 09:04 AM #15
usually ginagawa ng mga mekaniko yan to rule out the cause of idle misfire, but it should be temporay only to determine if the egr is causing the misfire. egr is used to reduce the exhaust gas temperature na nag ca-cause ng high NOx (nitrogen oxides) emissions.
Since you got this 2nd hand, its a good idea to change the drive belt (its cheap anyway). Also...
