Results 1 to 16 of 16
    Apr 2008
    Can you help me figure what this is in the middle, it seems like a foil:
    http://img407.imageshack.us/i/imagesvm.jpg/
    Quote Originally Posted by hammerhead2 View Post
    Looks like a gasket inserted between the joints.
    May 2009
    Looks like a cigarette pack to me....
    If thats an EGR tube, it could be an improvised blanking plate??
    Fortune na menthol na pack o di kaya champion na menthol na cig pack
    Apr 2008
    Should there be one?
    Yes but normally the edges should not stick out like that. It should be flush with the edges.
    Apr 2008
    Thank you gh.
    mukhang dinaya at sinarhan ang egr. parang aluminum softdrinks can
    Apr 2008
    Quote Originally Posted by t2erns View Post
    Ano implication nun?
    Jun 2008
    sa tingin ko yan ay improvised blanking plate. Kaya may nakausli kasi yan ang hawakan para isingit between joint.
    Kung egr yan malinaw na nakadisable na ang function ng valve. Short cut remedy baka tamad maglinis ang may-ari kaya mausok ang makina.
    Apr 2008
    Quote Originally Posted by weisshorn View Post
    Uhm i did not put it there. Should i complain kung casa me gawa nyan? Me negative effect ba ito?
    Jul 2003
    if there is actually a slot to insert and move that thing, maybe the original sheet could have been lost or removed intentionally.
    Jun 2008
    Oh sorry. I don't know that that picture is from your car. Akala ko sa iba yan. Kung egr nga yan ok lang wala naman pasama mangyayari sa makina. Hindi lang gugustuhin ng mga environmentalist kasi ang egr is to minimize NOx emission ng sasakyan.
    usually ginagawa ng mga mekaniko yan to rule out the cause of idle misfire, but it should be temporay only to determine if the egr is causing the misfire. egr is used to reduce the exhaust gas temperature na nag ca-cause ng high NOx (nitrogen oxides) emissions.
    May 2009
    a.k.a. EGR Delete Kit ni Juan dela Cruz.....
What is this?
