Page 2 of 2 FirstFirst 12
Results 21 to 27 of 27
    Sep 2009
    #21
    Quote Originally Posted by yourman_2nd View Post
    sir pagnaka menor ka, pag ba tinapakan mo ang gas pedal ng sagad (tip toe) ayos naman ba ang pag akyat ng RPM? or kahit naka minor, di makaabot ng mataas na rpm yung makina? kung pag naka minor ka maganda ang rebolusyon ng makina hanggang sa halos red line, nasa transmission or axle na ang problema. pero kung kahit naka minor ka at di maka rebolusyon yung makina hanggang abot sa red line, sa makina ang problema. try mo palitan ang spark plugs mo ng oem. ganyan din nangyari sa xtrail (AT) ko dati, akala ko yung iridium spark plugs ko okay pa kahit 2 yrs na sya, walang hatak pag abot na sa 4,000 yung rpm. pinalitan ko ng oem spark plugs, ayos na sya.
    Sir yun oto ko this week lang sluggish pero pag menor ok naman rebolusyon abot redline. so most likely sa transmission or axle ang problema? ano naman kaya ang posibleng sira.
    #22
    Quote Originally Posted by jon_212405 View Post
    sir ano po oto nyo?
    Apr 2024
    #23
    Normal ba kapag 4th gear ka tapos downshift sa 3rd gear tumataas rpm kahit inde ka naka apat sa gas
    Jan 2009
    #24
    Quote Originally Posted by Rjmar View Post
    Yes...⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀⠀
    Jun 2011
    #25
    Opo, dahil sa momentum ng speed galing 4th gear.
    #26
    agree with bxr.
    when you shift from 4th to 3rd gear, the momentum of the vehicle is the one pushing the engine to turn faster and not vice versa.
    Jan 2009
    #27
    To add, that's why you have to be careful when downshifting, especially on manual transmissions (M/T), to prevent over-revving the engine beyond its operational range. On your manual, it will often indicate the maximum speeds for each gear.
    As an example, here's info for the 2nd Gen Innova:
Walang Hatak * High RPM
