Results 21 to 40 of 55
    Tinatakot nyo naman yung bata. I've seen engines never been ran for 10 years and started with no pre-lubrication with no effects whatsoever. Walang kaso yan may oil film pa din between wearing parts basta huwag lang i-high rev until the oil circulates. Kung gusto sure gawin mo suggestion ni innova, patakan mo ng oil sa spark plug hole. Pati na din cylinder head buhusan mo mga 1 cup new oil then crank by hand sa crankshaft pulley.
    Pull out the spark plugs baka kinalawang kaya ayaw mag start. And yes do drain the old gasoline and change with fresh batch. Brakes? Run with the brake pedal pressed down to clean the brake surfaces, preferably in forward and reverse. Pag ok na dalhin mo sa nearest shop for a oil change and tune up.
    Hindi tumitigas ang langis. Tamod yun nagiging sago.
    Hindi sa tinatakot. Dapat talaga matakot.
    Pag ganyan katagal walang activity eh kailangan mo na idrain lahat.
    Baka idedare pa start. Eh doon din bagsak, kailangan na din palitan.
    Yung mga 20year old car tinatamod din pag wala gamitan. Sticky.
    Jul 2013
    #22
    If your immediate goal is just to start the engine, I suggest the ff:
    1) Drain old gasoline. Replace with fresh/new gas. (Yung genset ko, isang buwan lang matengga, ayaw ng umandar ng tuluyan dahil sa "panis" na gasolina)
    2A) If engine is fuel injected, check fuel pump if it is priming fuel. Turn key to ON (not start) and try to hear some hissing sound under the rear seats. Kung may sound, most probably okay pa fuel pump.
    A more complicated and messy way is through the hose going to the fuel filter which should shoot gas if key is turned ON.
    2B) If engine has carburetor, you can still try the succeeding steps before deciding to overhaul the carb.
    3) Check if there is electrical current delivered to the spark plugs. (Google mo na lang easy way to do this).
    If you have kuryente sa #3, then good.
    4) Replace spark plugs. No sense in testing since luma na yung naka-kabit.
    5) If you want, put a tablespoon or two of motor oil through the spark plug hole.
    For fuel injected engines, some error codes will appear (check engine light or CEL) prior to starting the engine if there is some problems sa electronics and sensors. Kung wala naman, you can try starting the engine the normal way.
    Oct 2009
    #23
    bat naman kasi matatakot.
    pag andar ba eh ibyahe agad ng long distance..syempre hindi diba.paandarin muna after na umadar saka i check lahat ng dapat icheck..ano delikado dun....
    i think our friend is now well informed [emoji2]
    May 2018
    #25
    I agree na sana hindi na dapat ni try i-start, but 110% sigurado ako na lahat tayo dito (incuding me) yun din ang unang gagawin.
    May 2018
    #26
    Yes.
    Ang mas importante (sa tingin ko ha) wag nang pilitin, kahit tumakbo pa ulit ito. Para di ka gumastos sa wrecker, tow mo na lang ng iba nyong kotse* papuntang talyer.
    Wag muna I try imaeneho sa daan kasi delikado nga. Even if it does start, hindi mo masasabi what can possibly fail after all those years of neglect. As much as he loves you, I don't think your grandpa (God bless him) would want another family member, or an innocent 3rd party to join him that way. Besides, I'm pretty sure it would honor his memory to TLC his car back to roadworthy condition.
    *Basta di frozen ang brakes & yung gulong ok pa. Sigurado ako meron kayong iba pang sasakyan kasi if your family can forget about the existence of a car for over 5 years, it's not the only car in the family...
    Sep 2006
    #27
    Now let's talk about the tires...
    Quote Originally Posted by SoleusBB View Post
    exclude me and some guys
    Sep 2006
    #29
    I wouldn't either
    May 2018
    #30
    You're... not... curious??? (Ei, I'm just kidding! )
    Devil on shoulder: Subukan mo... malay mo mag start na parang walang nangyari, eh di may ma-ikwento ka pa sa Tsikot Forums! Heee heee heee...!
    Angel on other shoulder: Wag! Masisira yan...
    May 2009
    #32
    You should have not started it in the first place without opening the engine. After 5 long yrs. pretty sure all the lubricating oil in the piston and rings are all dried up. Congrats, you have scratch the cylinder walls of your engine. The oil in the pan are very viscous and you might have only checked what's in the dip stick. Have a mechanic check it.
    Quote Originally Posted by suysuy View Post
    My grandfather died 5 years ago and he left a kia picanto in his garage. I tried to start it kanina however it only cranks. I already filled it with fresh gasoline 4 liters but it still would not start. Engine oil is fine. Fuel line is fine no leaks. This was in good running condition before he left the mortal world.
    Any troubleshooting tips?
    Sep 2012
    #33
    bayaan nyo na nagawa na nya ma start eh :-)
    To TS, isipin mo na lang na training ground mo yan para mag kalikot ng car DIY tapos lahat ng gagastusin mo is tuition fee.
    Madami ka coach dito
    Good luck and happy DIY
    Jan 2009
    #34
    Nobody is bringing it up so I’ll just ask for it... can the OP post a picture of the engine bay?
    I’m less worried with the engine being cranked before fluids were changed. Damage, if any, is negligible because there’s hardly any load applied to it and the motor surfaces isn’t totally devoid of oil even after 5 years. Ease up on the fellow and just focus on the elephant in the room.... which is the no-start condition. Don’t get me wrong... the OP should change out the oil eventually, but at this point, it’s not super critical that he does.
    I’d check the electrical systems for infestation or critter damage. Injectors may also need cleaning.
    Mar 2004
    #35
    Pretty sure not all of us will do it ...
    #36
    Not me...
    Sa ngayon litong lito na si TS sa dami ng nag suggest. [emoji16]
    Aug 2008
    #37
    Basta, pakita niya dapat agad sa qualified mechanic kung clueless siya on what and what not to do.
    Jul 2013
    #38
    *suysuy
    It's been 2 days since the thread was started...
    Nag-start na ba yung car mo?
    #39
    same situation here, car is sitting for 2 years. Mga nagawa ko na emptied fuel tank, replace fuel filter, lubricated front brakes, bleed brake lines. Coming soon change oil, clean sparkplug, buy new battery, put some oil sa sparkplug hole to lubricate the cylinder wall, change/flush the radiator fluid, clean carburetor. Haaaaay dami pa
    Apr 2014
    #40
    Quote Originally Posted by a3n3as View Post
    Did you start the car first or replaced the parts right there and then?
    I think that is what majority of the people here would love to know.
Vehicle not started for 5 years... What to do?
