Results 31 to 37 of 37
- Jun 2005
- 3,300
August 20th, 2015 09:55 PM #33
- Aug 2015
- 109
August 21st, 2015 10:35 AM #34mga sir magkano po ba yan helicoil? meron po ba nian sa mga auto supply? hindi ko po alam kung saan yang benavidez, taga laguna po ako. thanks
- Jun 2005
- 3,300
- Aug 2015
- 109
August 21st, 2015 10:58 AM #36napansin ko din po na mejo gumanda ung hatak between 1k - 2k rpm, pero parang humina naman ung 2k rpm pataas ung parang galit na galit ung makina. dati shift ako between 2k -2.5k rpm. ngayon po bago mag 2k nagshishift na ko. malakas po ata un sa gas? normal ba yun pag bagong adjust valve?
- Aug 2015
- 109
August 21st, 2015 11:05 AM #37thanks po sir sirkosero. naibiyahe ko na ung auto, wala naman leak pero 1 oras lang. tingnan ko po muna kung magleak sa mga susunod na araw.
You can always use another size as long it does not go beyond 5% in diameter difference. Check...
Low budget yet good quality tires
