Results 1 to 5 of 5
April 19th, 2011 10:30 PM #1
Need your thoughts guys.
Will adjusting the valve clearance to factory spec a way to go on a decade old diesel engine?
say for example current mileage is 350K+. Or should it be a bit tighter than the usual factory spec?
Thanks in advance.
- Jan 2005
- 445
- Jul 2010
- 165
April 25th, 2011 01:24 PM #4Adjust it back to factory specs. The measurement is usually indicated under the hood of the vehicle. They say that its good to have the valves re-adjusted every 40k
April 27th, 2011 01:35 PM #5
As the saying goes "It is more desirable to err towards a looser valve clearance than a tight one".
Why? tight clearances will have detrimental effects to your valves due to insufficient time to cool the valves especially the exhaust valves. The only time that the valve will cool is whne it contacts the valve seat.
Plus the fact that a very small clearnce will somehow affect the sealing of the combustion chamber.
hth
Xiaomi E-Car
