right after the air filter compartment.
Boknoy, yep, parehong mga diagnostic ang ni refer natin. Pang Nissan yung CONSULT II.
On the MAF, it is very sensitive... if its not dirty, it can be regrounded if the volt reading is "off". You can get a lot of info on MAF regrounds from Google (although this is usually for the GA and SR engines but it should be more or less the same).Bihira ang masira ang MAF that it'll need replacement IMO, unless natamaan siya or something (or if its miscalibrated, theres an adjustment screw for that). Its located right after the airbox and before the intake plenum where all the hoses/PCV meets up so its not susceptible to oil damage.
On the Sentra, cleaning it with contact cleaner every 10,000km is ok. The MAF of the NIssan QG16DE (engine ng bagong Sentra) is particularly sensitive (as in night and day difference in performance before and after its cleaned). Before i had the one in our Sentra cleaned, hirap umabot ng 120kph... after it was cleaned, tuloy-tuloy until 160++ ako on the same stretch of road.![]()
ano po yung contact cleaner? i still have my old MAF with me, sa tingin ko malinis naman. and how do i adjust/recalibrate it, i mean if i adjust the screw, how would i know if its at the right calibration?
Signature
The calibration can only be done if you have the CONSULT unfortunately... I've seen several guys adjust this, thinking it was the adjustment for the idling...
Contact cleaner, this is used for cleaning electricals/contacts.Meron sa CASA usually or you can check also at the hardware. Kung "off" yung reading, its a MAF reground (adding an additional ground wire) and cleaning combo thats done.
hmmm, masyado palang technical and requires the casa. hehe, sila nga ang nagrecommend na palitan yung MAF.
Signature
the MAF got busted again in just around 2 weeks. nissan casa replaced it under warranty, pero hassle pa rin yung pagpunta dun dahil ang layo (45kms)!
Signature
oo nga, ang bilis naman. defective yung replacment MAF sensor o may ibang underlying problem?
pansin ko, post kaagad si MBT, talagang interesado sa patrol mo boybi
nya ha ha ha
matagal ko ng hindi ginagamit yung finer filter, way before nasira yung unang MAF. ewan ko ba bakit minamalas ako dyan sa MAF na yan.
Signature
Nangyari din sa akin yan dalawang beses na. kasi madalas 140-160kph takbo ko sa highway. Yung dinala ko sa casa nilinis lang yung mass airflow at ok na. sensitive daw talaga mga new efi diesels. yung trooper ng kaibigan ko ganun din. try Total diesel din. mas maganda hatak at mas di mausok.Originally Posted by boybi
hindi naman generally yung MAF sensor yung nirerefer when people say that "new diesels are very sensitive" hehe. generally yung fuel delivery system ang tinutukoy
