Results 11 to 20 of 45
October 11th, 2005 04:53 PM #11
try to touch base with Auto.Xer (a.k.a. Ferman Lao) of Fusion R. They have turbo charged a new Honda Jazz 1.3 CVT.
They basically installed a turbo, intercooler, and a piggyback chip (SMT).
Based on the dyno readings at Autoplus, hp and torque rose very significantly!
October 11th, 2005 04:58 PM #12
IMO... the only 1.3L engine worth boosting is from the Mazda RX-8. :bwahaha:
October 11th, 2005 05:27 PM #13
Originally Posted by mazdamazda
Personally though, I'd rather buy a higher displacement car.
October 11th, 2005 05:32 PM #14
a 1.8 or 2.0 compact sedan would be much more logical, better yet turbocharge the 1.8/2.0 sedan and you're good to go!
TheOneThatIs
- 1,306
October 11th, 2005 05:32 PM #15If that 1.3L car is just your beater car, and you have money to burn, why not?
October 11th, 2005 05:38 PM #17
and i think ung mga gumagawa ng ganun, para di halatang matulin..kasi iisipin ng tao, 1.3L lang un....kaya makakagawa ng frustration sa hahamon sa kanila...
October 11th, 2005 06:38 PM #18
Originally Posted by woodfire
according to Ferman, the jazz (turbo) performance is almost at the same level of a Civic SiR before the vtec kicks in.
October 11th, 2005 07:00 PM #19
di naman siguro useless, but probably not worth the money you're gonna spend.
Sabihin na natin mag spend ka ng around 80K-100K (all-in na yan, pati iba pang kailangan, IC, fuel management, injectors, whatever), the power you will be gaining is not that much in relation to the the amount you will be spending and it's still a 1.3 with a lot of limitations.
If I'm in that position, mag swap na lang ako ng makina with a bigger displacement.
my 2 cents
October 11th, 2005 07:51 PM #20
pero most 1.3L cars are lightweight, almost or a bit over 1000kgs:
vios, jazz, getz, charade, pride...supercarry/every, hi-jet vans... kung maging 160hp-200hp engine parang lilipad na ung sasakyan..parang power ang weight ratio..
pero kung figures alng pagbabasehan, parang lugi ka sa gagastusin mo sa 1.3L car mo...
People Replace Their Gas-Powered Cars Every 12 Years, While Electric Cars Are Renewed Every 3...
Hybrids and EV
