Results 1 to 20 of 31
Threaded View
    Aug 2008
    Ride is MT Toyota Avanza 1.3J. acquired october last year. This afternoon nabigla ako kasi nabitin ako sa isang steep road (about 45 degrees) inside Baguio Center Mall basement parking. 3 adults nakasakay including me. Before umakyat sa steep road dahan dahan muna ako kasi hindi pantay yung metal cover nung drainage system (dunno the exact term he he he basta yun na un) before the road so wala talaga bwelo. From fully stopped(car is inclined to the steep road) I shifted to 1st gear and depressed the gas pedal, dahan dahan umabante then about 1 meter into the climb nag shudder tapos namatay na yung engine. Parang hindi talaga kaya ng makina. Nabigla me talaga kasi hindi naman dati nabibitin dun sa steep road na yun maybe nakabwelo lang me before. Mabuti na lang walang sumusunod na car, wheeow!! So habang nakatigil ako dun sa gitna ng road inistart ko ulit, i tried again (2nd) kasi naisip ko baka hindi lang timing yung pagtimpla ko ng clutch and gas pedal and on my next try the same happened umabante ng konti, car shuddered and engine died again. Tried again (3rd) but this time i let the cluth slip a little para hindi mamatay yung makina pero nung kumagat na ung clutch the same happened again... i tried again but this time i pressed the gas pedal a little bit hard allowing the engine rpm reached 2k and releasing the clutch faster than normal para makakuha agad ng momentum but again the same happened.. so talagang hindi maka akyat... umatras nalang ako hanggang sa baba then bumwelo ako nang konti ayun naka akyat at last.. Ganun ba talaga ang avanza e low pa ang gearing neto di ba meaning high torque on the wheels right? pano na lang kung yung car is caught up in traffic sa steep road then talagang stand still??? Kinabahan tuloy ako sa car ko bka under powered nga talaga... pero malakas naman ang hatak ng primera sa patag... May naka experience na po ba dito same as mine? Wala po kayang problem sa clutch or something kaya hindi maka akyat? Comments are greatly appreciated.. THNX..!
    Last edited by pjkhyra; April 3rd, 2009 at 01:25 AM. Reason: add additional details
Car cannot climb steep road..
