Page 2 of 2 FirstFirst 12
Results 21 to 31 of 31
    Sep 2006
    #21
    I think kaya sa primera. hehe
    Jan 2003
    #22
    No sir, madalas ako mag park dun... hindi naman ako alangan kasi makitid naman ang width ng avanza kaya madali lang i mani obra dun sa kurbada sa taas... the way i handled the situation i think is the problem medyo natipid ang pag rev and i forgot to engaged the handbrake h[COLOR=Blue]e he he...
    so change na natin ang thread title into...driver cannot climb steep road
    Aug 2005
    #23
    Pag naka M/T, its power management. sa flat roads, OK na mag shift at 2,000 RPM, pero sa mga inclines, pag bumababa na ng 2500, better down shift para di mabitin.
    Aug 2006
    #24
    My company is a Toyota country so all our cars/suv/mpv are Toyota! We also have steep level parking at the office.
    Iisa lang ang reklamo ng mga co-employees ko na kumuha ng 1.3J Avanza mahina humatak kahit sa even roads and much more sa uphills. You will need to rev higher prior to steep roads otherwise you'll stall.
    Kahit low fuel na ang tank dapat di ito issue, dahil pag uphills all the fuel will go to the rear portion of the tank which is where the fuel feeder line was. Kung downhill issue ang low fuel sa Avanza, Innova, Fortuner and Hi-lux kasi lahat ng fuel pupunta sa front portion.
    #25
    kulang 2k for that incline though i dont believe that is a 45 deg climb. I have encountered enough 45 degree climb (all you see is the sky) and descent (oops no road down) off road to know that in normal parking lots it would wreck havoc to your car's mid-part and underchassis.
    Jul 2003
    #26
    Quote Originally Posted by kompressor View Post
    I see. Pero kung 45 degrees nga talaga ang angle niyan eh sobra namang tarik niyang mall parking ramp na yan. Last time ako nakakita ng ganyang parking ramp eh sa columbia tower sa greenhills and hirap na hirap umakyat even mga sedans.
    Think of an equilateral triangle. Ganun ang 45 degrees. Kung ganun talaga ang tarik niyan eh wala nang kasalanan yung sasakyan mo. Kung ako nasa situation mo eh paatras ko iaakyat ang sasakyan para mas makitid ang gear.
    The equilateral triangle have 60 degrees angle on all vertex. An equilateral
    triangle is also an equiangular triangle. 60 + 60 + 60 = 180 degrees.
    Nov 2007
    #27
    ot
    share ko lang yung subd na pinuntahan namn sa baguio with 12 pax and 4 children in the van sobra ang tarik nito kinulang pa ang video ng cp ko
    [ame="http://www.youtube.com/watch?v=sWcLLrCmDsA"]YouTube - uphill resthouse MB100[/ame]
    Apr 2009
    #28
    Sir, I'm a newbie in the forum, but I thought of sharing my situation which happens to be similar to that of the thread starter's.
    I drive a 2002 Diesel Mitsubishi Adventure Super Sport. I have observed that for the two times that we have driven to the steep roads of Tagaytay and Batangas (Tagaytay Highlands and Punta Fuego in Nasugbu), my Adventure encounters this difficulty in climbing steep trails. During these climbs, the car encounters difficulty on the 2nd gear so I'm forced to use the 1st gear until we reach the top. I don't know if the Adventure has a problem with the engine or it's just a normal occurrence among cars like these. BTW, the car doesn't encounter any engine and transmission problems on flat roads, but on steep ones, this has been the second time that I've gone through this. May sira ho ba ang kotse ko o baka naman ako lang ang may problema? Inputs naman po mga sirs and thanks in advance!
    Oct 2003
    #29
    kung hindi naman driver error you can check:
    1. electricals
    2. fuel lines
    #30
    mahirap talaga ang pa-akyat lalo na kung sanay ka sa flat roads... no pun intended but most of the time eh the problem comes from driving style. secondary na yung makina - in the case of pjkhyra - tama ang mga naging suggestions ng fellow tsikoteers natin. he should have not been timid in stepping on the gas and rev the engine hard (pero syempre not too hard naman). we were in baguio last week of March and may similar experience ako had to climb a steep road (45deg din siguro more or less, maybe more... langit na yung nakikita ko eh) and at almost stand still naka inclined na. shifted to 1st-gear revved up the engine to 3.5k before releasing the clutch and there was no letting off the accelerator after that, mga 200meters na ahunan din give or take. btw... my ride is a terrano with z24 gas engine with 4wd option pero that time naka 2wd lang ako. we're 4 adults and 1 child - kaso parang 6 adults din kasi katumbas ng weight ko tatlo. hehehe.
    Jun 2009
    #31
    remember to always:
    slowly depress the clutch otherwise the engine WILL stall..
    note: don't be afraid to rev the engine.. rev the nuts off of the 1.3 liter.. joke.. rev it past 2K RPM
Car cannot climb steep road..
